Multiple Instances Running On 2 Dialogic Cards.
Hello, i have two 4-port dialogic cards on the same machine and I would like to have 2 instances of VG running each using its own card.
How can I achieve that and how must I configure each instance of VG in order to have it use the right card?
Marek.
Only one instance of VG can run on a machine.
Why do you want to run two instances?
Here's the issue, we have 2 dialogic cards with 4 ports each.
But we have ordered a 8 port VG license and we would like VG to use both cards.
How can we achieve this?
Marek.
Just place both cards in the computer...
After enabling VG with the 8 line license you will be able to have VG control the 8 lines on the two cards...
