Guest kparkk Report post Posted 01/27/2006 02:19 AM Using VG For DIalogic When I change the setting for the minimum message length in the voicemail manager to be 10 secs, and press "Save & Exit", then reopen, the new setting is not taking effect, it always shows minimum message length equal 0. Even by modifying the vmboxlist.xml to have min message length = 10 secs, I still get a 0 secs in the voicemail manager .... What is happening? and how to fix this issue? Thanks. Share this post Link to post
Guest kparkk Report post Posted 01/28/2006 01:50 AM Do you kindly have any info for this post? Thanks. Share this post Link to post
SupportTeam Report post Posted 01/30/2006 09:48 PM After setting the min and max values press the "Reset all Voicemail boxes to this setting" button. The values for min/max lengths for all voicemilboxes listed in VmBoxList.xml will be reset accordingly. Share this post Link to post
