D/240sc Voiceguide E&m Wink Start T1
Hello,
I'm currently evaluating the Voiceguide with the following set up:
PBX (E&M Wink Start T1) --> D/240SC-T1 (Voiceguide)
Do you have any sample or whitepaper for this setup with fractional T1 (Less Than 24 ports) license i.e start off with 4 port Enterprise then increment it later.
rgds,
vincent
A sample configuration for VoiceGuide for use with E&M Wink Start T1 (also known as Robbed Bit) is included with VoiceGuide for Dialogic patch, see: "Sample Config for 24 port using one T1 robbed bit.xml" file.
You can just open the first few ports on the T1 line, but you have to ensure that the PBX is configured to only send calls on those ports...
