Taking Back A Dial And Conference Call
Hi, after making a Dial and Conference call using a dialogic JCT card (but the standard voiceguide tapi version), is it possible to take back the call after the conference has been connected?
What I want to do is hangup the 2nd leg only after a timeout and reconnect to the original inbound call to process further. Basically, pass the call on to the voicemail system or run any further modules.
I see from the debug trace that each call leg is handled by VG/Tapi and that when you hangup, each leg is terminated separately.
So, in a nutshell is it possible to "un-conference" or have the software changed to support this highly use feature?
Not in the TAPI version.
It is possible in "VG for Dialogic" though.
I think I've got a work-around solution to this, which works with the v5.2.5029 version you posted recently.
I've attached a test script, I wonder if you would be good enough to take a look at it and tell me if there is anything wrong with it.
Essentially, the script runs a dial & conference connection. The timeout path runs a VBS script with the following code:
'attempt to hangup bridged call here...
iLineID = $RV_LINEID
iNewLine = "$RV[Conf_LineID_2]"
result = vg.Bridge_Disconnect(iLineID, iNewLine)
vg.Line_Hangup iNewLine
vg.Run_ResultReturn iLineID, "success"
set vg = nothing
This disconnects the bridge, then hangs up the second leg. The original call is "retrieved" and the script can continue, say to play a message or pass teh caller to voice-mail.
This route is taken if the call is not answered, after a timeout path of say 30-60 secs. If however the call is connected, then pressing 1 bypasses the timeout path and runs an endless loop, which keeps the call open. (Unfortunately, the 1 is heard on both lines, but is can live with this.)
Now this works, but is not ideal. I wonder if you could improve this, perhaps allowing the 2nd leg to take the call without the 1 being heard on both lines (which it is) and perhaps having some way to "tread-water" without the cumbersome endless null play module? perhaps allow the "success" path to be taken when the call connects (it doesn't seem to at the moment)
One other nuance I have noticed is that an inbound call in to the line that is being bridged (perhaps part-way thru the process) is sometimes connected. I guess this can be eliminated by specifying which lines to use.
This script could potentially save me a lot of effort trying to bounce unansered calls back to the IVR system for call recording/message taking. I really would like to see this built-in to the call-transfer process somehow, or perhaps improved in some way.
Would you be kind enough to spare a few minutes to mull it over with your dev-team and warn me of any hidden issues or consider improving it in some way?
Many thanks!
PS: If you are wondering why I need to do this, its because my PBX doesn't queue on transfered calls, but bridging calls does queue, otherwise I would use one of the announced conference options.
The only immediate comment would be to not use this path in the [DoNothing] module:
on {timeout 0} goto [DoNothing]
Specify a long timeout - like this:
on {timeout 600} goto [DoNothing]
