Harry L. Roberts Report post Posted 02/01/2006 08:00 PM I maybe having a similar problem. I'm trying to do the following; strFileToPlay = "C:\1stMy.wav" PlayWAVFile iLineID, strFileToPlay strFileToPlay = "C:\2ndMy.wav" PlayWAVFile iLineID, strFileToPlay Sub PlayWAVFile(ByVal iLineID, ByVal strFileToPlay) set Objvg = CreateObject("VoiceGuide.CommandLink") Objvg.Play_Start iLineID, strFileToPlay set Objvg = Nothing End Sub Actual file names were not used. What happens is the first file starts to play and then the Second file starts to play before the first file is finished playing. What can I do to let the first file play completely before the second file begins to play? Share this post Link to post
Harry L. Roberts Report post Posted 02/01/2006 08:17 PM I've attached a trace of my problem. 140554.41 4 cl Play_Start C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.wav 140554.42 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.wav 140554.45 0 comlg 1.wav,2.wav,3.wav 140554.48 4 tw wav->vox convert end 427093,C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.vox,1,0,, 140554.53 4 play start ok, lPlayId=427171 140554.56 4 cl Play_Start C:\Program Files\VoiceGuide\system\voice\1.wav, C:\Program Files\VoiceGuide\system\voice\2.wav, C:\Program Files\VoiceGuide\system\voice\3.wav 140554.59 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\3.wav 140554.63 4 tw wav->vox convert end 427265,C:\Program Files\VoiceGuide\system\voice\1.vox,C:\Program Files\VoiceGuide\system\voice\2.vox,C:\Program Files\VoiceGuide\system\voice\3.vox,1,0,, 140554.64 4 play start ok, lPlayId=427312 140554.67 4 tw PlayEnd 4 427171 140554.70 4 play end id=427171, (old ID) current id=427312 140554.72 4 tw DialogicEvent 129,TDX_PLAY,427171,0,0,,, 140554.75 4 event ScriptEventCode TDX_PLAY, code=129, state=1501 140554.78 4 LsRunWaitTillFinished TDX_PLAY,EV_UNKNOWN_129 140554.81 4 path {TDX_PLAY} not found 140556.23 4 tw PlayEnd 4 427312 140556.25 4 play end id=427312, (current ID) Trace is Attached. As you can see as soon as the 2nd file begins to play the 1st one stops. That makes sense. How can I start playing the 2nd file only after the 1st file is finished playing? I'm sure there is something very simple that I'm overlooking. Share this post Link to post
Harry L. Roberts Report post Posted 02/01/2006 08:41 PM Here is the log file that I forgot to add to the above message. 2006_02_01_Trace_Showing_VB_Script_File_Play_Overlap.zip Share this post Link to post
SupportTeam Report post Posted 02/01/2006 10:11 PM What happens is the first file starts to play and then the Second file starts to play before the first file is finished playing. Issuing a Play_Start COM command will resuklt in VG stopping whatever is being played or recorded on the line and the newly supplied sound file will begin playing. How can I start playing the 2nd file only after the 1st file is finished playing? You will need specify the files to be played in one call. Try this: strFileToPlay = "C:\1stMy.wav,C:\2ndMy.wav" PlayWAVFile iLineID, strFileToPlay Sub PlayWAVFile(ByVal iLineID, ByVal strFileToPlay) set Objvg = CreateObject("VoiceGuide.CommandLink") Objvg.Play_Start iLineID, strFileToPlay set Objvg = Nothing End Sub Share this post Link to post
