Send Dtmf Digits Based On Rv Or Db Query
I am developing a VG application which exchanges strings of DTMF digits with a remote telephony device.
I am trying to find a way of sending DTMF digits to the remote device from VG where the DTMF digits required to be sent are the result of a database query.
Can you advise on the correct syntax to be used in the in the Get Number module or Play Sound Module to make this happen.
Thanks for the prompt response I have looked at three links provided and can confirm that
this is what I have tried to do. I have succesfully retrieved the RV from Excel, but I am unable to dial it because I think I am screwing the syntax up
can you give me an example for instance if I want to dial the string
123 followed by the digits from the results variable from the DB query (say 456) then followed by digits 789
I cant post a log - I am at home and VG in the office.
In the Play module you'd specify something like this:
123$RV[MyQuery_1_1]789
Post your script and the trace capturing the call. We can then see what is happening on your system.
