COM initiated conference in v5.2.5015
When using dial and conference, any DTMF from either line (ie: each leg) will cause the bridged lines to hangup.
The documentation states that just an asterisk/star/* DTMF signal should end the call.
I am using v5.2.5015, here is a log snippet - The trace clearly shows some sort of error in the log. Can this be fixed please so that only 1 dtmf digit is used (*) as per the documentation? (Having any digit end the call may end the call prematurely).
152907.29  7 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
152907.29  7 ScriptEventCode 9014 iLineState=1910
152907.29  7 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
152907.30  6 rv    ns add [Conf_DevName_1]{dxxxB1C1}
152907.31  6 rv    ns add [Conf_LineId_1]{6}
152907.32  6 rv    lg add [Conf_DevName_2]{dxxxB1C2}
152907.34  6 rv    lg add [Conf_LineId_2]{7}
152907.34  7 rv    ns add [Conf_DevName_1]{dxxxB1C1}
152907.36  7 rv    ns add [Conf_LineId_1]{6}
152907.36  7 rv    lg add [Conf_DevName_2]{dxxxB1C2}
152907.36  7 rv    lg add [Conf_LineId_2]{7}
152907.38  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
152907.39  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
152907.40  7 state Conferenced to 6 (dxxxB1C2) at 15:29:07
152907.41  6 state [RunWait] Conferenced to 7 (dxxxB1C1) at 15:29:07
152909.03  6 timer fired EV_TIMEOUT_REPLAYMSG
152909.04  6 ScriptEventCode 9005 iLineState=1101
152909.05  6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
152909.06  6 state [RunWait] Playing ()
152909.07  6 ScriptEventCode 8001 iLineState=1100
152909.08  6 LsPlayMsg EV_PLAY_FINISHED
152909.08  6 eng  set timer EV_TIMEOUT_REPLAYMSG time=5
152909.09  6 timer set 5  EV_TIMEOUT_REPLAYMSG
152914.11  6 timer fired EV_TIMEOUT_REPLAYMSG
152914.11  6 ScriptEventCode 9005 iLineState=1101
152914.13  6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
152914.13  6 state [RunWait] Playing ()
152914.14  6 ScriptEventCode 8001 iLineState=1100
152914.14  6 LsPlayMsg EV_PLAY_FINISHED
152914.15  6 timer set 10  EV_TIMEOUT_HANGUP
152914.16  6 timer set 25  EV_TIMEOUT_GOTOMODULE
152922.04  7 dtmf 1  (66392,49,2)
152922.05  7 ScriptEventCode 49 iLineState=1910
152922.05  7 LsXferWaitEndCall 1
152922.07  7 ERROR 5.2.5012 Error_ScriptEventCode: line=1390:9: Subscript out of range state:1910 event:49
152922.07  7 rv    lg add [Hangup Time]{03/02/2006 15:29:22}
152922.07  7 state Hanging up call... [Error_ScriptEventCode]
152922.09  7 DialogicScUnroute dxxxB1C2</>dxxxB1C1 MATCH_ call
152922.11  7 DialogicScUnroute dxxxB1C2</>dxxxB1C1 MATCH_
152922.11  6 rv    lg add [Hangup Time]{03/02/2006 15:29:22}
152922.13  6 state Hanging up call... [2nd leg]
152922.14  6 RecSoundStop ok
152922.14  6 PlaySoundStop err=0
152922.16  6 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
152922.16  6 fnHangupCall end
152922.18  7 RecSoundStop ok
152922.18  7 PlaySoundStop err=0
152922.20  7 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
152922.21  7 state Waiting for a call...
152922.21  7 fnHangupCall end
We're not seeing this on our test systems - can you please update with attached .exe and try again - posting relevant section of the trace as before.
This .exe has more debugging in the relevant area.
VgMulti_5.2.5029.zip
Okay, running the latest patch above appears to work. If I press 1, the digit is ignored, if I press * it hangs up the call. However, there are a couple of errors listed in the log for the bridge section, see snippet attached below...
Complete logs are attached for a single call end-2-end.
This method of call transfer is using a standard "Dial & Conference" Call transfer module. However, slightly different results occur for a COM based bride call. The same error messages are issued to the debug log, (subscript out of range), but the call proceeds to hangup instead of ignoring the digits. See second log quoted.
Ideally, I would like the com-based call to ignore all but the asterisk on the line.
200327.59  7 callstate CONNECTED 66530,1,0
200327.59  7 WorkingModeTAPI@Connected=
200327.59  7 WorkingModeScript@Connected=
200327.59  7 2nd leg of call recieved CONNECTED event
200329.57  7 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
200329.57  7 ScriptEventCode 9014 iLineState=1910
200329.57  7 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
200329.57  6 rv    ns add [Conf_DevName_1]{dxxxB1C1}
200329.57  6 rv    ns add [Conf_LineId_1]{6}
200329.57  6 rv    lg add [Conf_DevName_2]{dxxxB1C2}
200329.57  6 rv    lg add [Conf_LineId_2]{7}
200329.57  7 rv    ns add [Conf_DevName_1]{dxxxB1C1}
200329.57  7 rv    ns add [Conf_LineId_1]{6}
200329.57  7 rv    lg add [Conf_DevName_2]{dxxxB1C2}
200329.57  7 rv    lg add [Conf_LineId_2]{7}
200329.57  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
200329.59  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
200329.59  7 state Conferenced to 6 (dxxxB1C2) at 20:03:29
200329.59  6 state [Transfer] Conferenced to 7 (dxxxB1C1) at 20:03:29
200339.11  7 dtmf 1  (66530,49,2)
200339.11  7 ScriptEventCode 49 iLineState=1910
200339.11  7 LsXferWaitEndCall 1
200339.11  7 ERROR 5.2.5029 LsXferWaitEndCall line=40 err=9:Subscript out of range
200339.11  7 ERROR 5.2.5029 LsXferWaitEndCall line=50 err=9:Subscript out of range
200339.13  6 dtmf 1  (65950,49,2)
200339.13  6 ScriptEventCode 49 iLineState=1910
200339.13  6 LsXferWaitEndCall 1
200339.13  6 path {1} not found
200345.65  6 dtmf *  (65950,42,2)
200345.65  6 ScriptEventCode 42 iLineState=1910
200345.65  6 LsXferWaitEndCall *
200345.65  6 path {*} not found
200345.65  6 rv    lg add [Hangup Time]{09/02/2006 20:03:45}
200345.65  6 state Hanging up call... [* pressed]
200345.65  6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_ call
200345.66  6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_
200345.67  7 rv    lg add [Hangup Time]{09/02/2006 20:03:45}
200345.67  7 state Hanging up call... [2nd leg]
200345.67  7 RecSoundStop ok
200345.67  7 PlaySoundStop err=0
200345.67  7 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
200345.67  7 state Waiting for a call...
200345.67  7 fnHangupCall end
200345.67  6 RecSoundStop ok
200345.67  6 PlaySoundStop err=0
200345.67  6 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
200345.68  6 fnHangupCall end
200345.68  7 dtmf *  (66530,42,2)
200345.68  7 ScriptEventCode 42 iLineState=900
200345.68  7 LsAwaitingCalls *
200345.71  6 devstate NUMCALLS 0 0
200345.71  6 tapi  callstate start
200345.71  6 tapi  callstate IDLE 65950 0 0
Com-Based Debug Trace:
202451.61  6 timer clear
202451.63  6 state [DoComTransfer] Running VB Script...
202451.63  6 rv    replace start: ['attempt to do a call bridge
iLineID = "$RV_LINEID"
'make the call...
iNewLine = vg.Dialer_MakeCall("150", "", cstr(iLineID), "none")
if iNewLine <> "" then
  vg.Run_ResultReturn iLineID, "[newcall]{" & iNewLine & "}"
else
  vg.Run_ResultReturn iLineID, ""  '< failed!
end if
set vg = nothing
202451.64  6 rv    ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\KTR\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\KTR}[$RV_STARTTIME]{09/02/2006 20:24:48}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[start]{timeout}
202451.66  6 eng  run vbs [wscript "C:\Program Files\VoiceGuide\temp\vbs_6_1_0209202451.vbs" //I //T:60] copy of script in: vbs_6_1_0209202451.vbs
202451.70  6 Run Script waiting. iRunWait=1 (shellid=1420, process=536)
202451.70  6 timer set 1  EV_TIMEOUT_CHECKONSTATE
202451.78  0 cl    Dialer_MakeCall 150, , 6, none
202451.80  0 Search for free lines in LineID range [6-9]
202451.80  6 dial  busy: active call
202451.81  7 dial  reserving [dxxxB1C2] as no list specified
202451.84  7 state      dialing [150]
202451.85  0 cl    Dialer_MakeCall script not loaded
202451.85  7 rv    clear
202451.88  7 timer set 3600  EV_TIMEOUT_HANGUP
202451.88  7 TapiCbTrigSet 65796 7003
202451.88  6 cl    Run_ResultReturn >>[newcall]{7}<<
202451.89  6 rv    ns add [newcall]{7}
202451.91  6 cl    module's runwait=1, WavPlayHasNowFinished=0
202451.91  6 timer clear
202451.92  6 state [RunWait] Playing
202451.93  6 state [RunWait] Playing (none)
202451.95  6 ScriptEventCode 8001 iLineState=1100
202451.95  6 LsPlayMsg EV_PLAY_FINISHED
202451.96  6 timer set 10  EV_TIMEOUT_HANGUP
202451.98  6 timer set 25  EV_TIMEOUT_GOTOMODULE
202451.98  6 RunModule PLAY end
202452.39  7 tapi  Reply (LineEvReply) ok 65796 0
202452.41  7 TcTrig.lTrigType = TcTrig_MakeCallForConferenceFinished
202452.41  7 Setting conference to occur in 3 seconds (not waiting for PROCEEDING)
202452.42  7 timer set 3  EV_TIMEOUT_BRIDGEAFTERDIALING
202452.44  7 TapiCbTrigClear
202452.45  7 devstate NUMCALLS 0 0
202452.45  7 tapi  callstate start
202452.46  7 tapi  callstate DIALTONE 66090 0 0
202452.48  7 tapi  callstate start
202452.48  7 tapi  callstate DIALING 66090 0 0
202452.51  7 tapi  callstate start
202452.51  7 tapi  callstate PROCEEDING 66090 0 0
202452.52  0 dial  start any summary:|6:hc>0|7:rdy=2|8:idx=0|9:idx=0|
202452.53  7 callinfo CALLEDID
202452.53  7 callinfo REASON
202452.55  7 ev    Lev_CallerID [0000,,150]
202452.55  7 rv    lg add [DNIS]{150}
202452.56  7 callinfo ORIGIN
202453.54  0 dial  start any summary:|6:hc>0|7:hc>0|8:idx=0|9:idx=0|
202454.66  7 tapi  callstate start
202454.66  7 tapi  callstate CONNECTED 66090 1 0
202454.68  7 callstate CONNECTED 66090,1,0
202454.69  7 WorkingModeTAPI@Connected=
202454.70  7 WorkingModeScript@Connected=
202454.70  7 2nd leg of call recieved CONNECTED event
202455.42  7 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
202455.43  7 ScriptEventCode 9014 iLineState=1910
202455.44  7 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
202455.45  6 rv    ns add [Conf_DevName_1]{dxxxB1C1}
202455.45  6 rv    ns add [Conf_LineId_1]{6}
202455.46  6 rv    lg add [Conf_DevName_2]{dxxxB1C2}
202455.47  6 rv    lg add [Conf_LineId_2]{7}
202455.48  7 rv    ns add [Conf_DevName_1]{dxxxB1C1}
202455.48  7 rv    ns add [Conf_LineId_1]{6}
202455.50  7 rv    lg add [Conf_DevName_2]{dxxxB1C2}
202455.51  7 rv    lg add [Conf_LineId_2]{7}
202455.52  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
202455.54  7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
202455.55  7 state Conferenced to 6 (dxxxB1C2) at 20:24:55
202455.56  6 state [RunWait] Conferenced to 7 (dxxxB1C1) at 20:24:55
202458.22  7 dtmf 1  (66090,49,2)
202458.23  7 ScriptEventCode 49 iLineState=1910
202458.24  7 LsXferWaitEndCall 1
202458.25  7 ERROR 5.2.5029 LsXferWaitEndCall line=40 err=9:Subscript out of range
202458.27  7 ERROR 5.2.5029 LsXferWaitEndCall line=50 err=9:Subscript out of range
202458.70  6 tapi  callstate start
202458.71  6 tapi  callstate DISCONNECTED 66532 0 0
202458.73  6 ScriptEventCode 9250 iLineState=1101
202458.73  6 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
202458.73  6 rv    lg add [Hangup Time]{09/02/2006 20:24:58}
202458.74  6 state Hanging up call...
202458.75  6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_ call
202458.77  6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_
202458.78  7 rv    lg add [Hangup Time]{09/02/2006 20:24:58}
202458.80  7 state Hanging up call... [2nd leg]
202458.80  7 RecSoundStop ok
202458.81  7 PlaySoundStop err=0
202458.82  7 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
202458.84  7 state Waiting for a call...
202458.84  7 fnHangupCall end
Finally, just would like to add that before using v5029, both methods would hangup the call for any DTMF digit on the line.
vgtest60209.zip
Glad to hear it's working.
The log entries you point out just mean that there is no script active on that line - which there isn't on the outgoing leg's line.
We're going to change these log entries to be more appropriate informational messages.
Yes! But not for COM !! Any digits cause hangup !!
okay - good !!
Please post your script. (.ZIPed)
Please also post the MMDDtw.txt trace of the COM initiated transfer situation.
Why are you using COM instead of the "Dial and Conference" from within a module?
I was using COM initially, because I figured I needed to obtain the line-id of the 2nd leg and pass this on to some subsequent code, but, this was before I discovered the $RV[Conf_LineID_2] variable. Since finding this new (to me!) var, I have been able to use the standard Call-Transfer module in Dial & Conference mode okay. So, I will skip the COM method for now.
I just reran my original com-based script using v5.2.5029 and it seems to work. I pressed a range of DTMF digits, but only the asterisk hungup the call. Attached is the script and 3 log files.
Sounds like v5.2.5029 reacts as you'd like it to DTMFs during COM initiated conference (and sounds like there weren't any issues DTMF reactions in normally initiated conference in either version).
The version available for download from our WWW will soon be updated to v5.2.5029 (or newer).
