Vbs Error
We purchased the professional version which states VBScript is supported. However when I run VoiceGuide, I see the following error in the event log:
102340.22 6 ERROR: COM interface not supported in this version.
This is the script I am trying to run
sReturnValue = vg.RvGet($RV_LINEID, "$RV[Get PIN (9)]")
Select Case $RV[Get PIN (9)]
Case 1167
vg.RvSet_RvList $RV_LINEID, "[Property ID]{101}"
sResult = "verify_passed"
Case 1210
vg.RvSet_RvList $RV_LINEID, "[Property ID]{102}"
Case 1321
vg.RvSet_RvList $RV_LINEID, "[Property ID]{103}"
Case Else
sResult = "verify_failed"
End Select
'vg.Run_ResultReturn $RV_LINEID, sResult
'set vg = Nothing
This worked with the trial version. Any help will be greatly appreciated.
Jim
