Guest force Report post Posted 02/04/2006 12:40 PM hi every time run the test script the it terminated after play the say numbers 8 module, not continue to the next module, (say numbers 7). i already update the lib_num2wav.vbs to say the number from 1 to 999 in arabic . what is problem? i sent the ( lib_num2wav.vbs,log file ,vgs file) Regards test.zip Share this post Link to post
SupportTeam Report post Posted 02/04/2006 11:49 PM In module [say Numbers 8] you have a path: on {success} goto [say Numbers 7] instead of that path use: on {timeout 0} goto [say Numbers 7] and you may also want to set the number or replays to 0, so that the module [say Numbers 8] only plays the number once. Youi can also use some DTMF triggered paths - but caller then need to press keys on their telephone keypad in order for those paths to be taken. Share this post Link to post
