Vb
hi
every time run the test script the it terminated after play the say numbers 8 module, not continue to the next module, (say numbers 7).
i already update the lib_num2wav.vbs to say the number from 1 to 999 in arabic .
what is problem?
i sent the ( lib_num2wav.vbs,log file ,vgs file)
Regards
test.zip
In module [say Numbers 8] you have a path:
on {success} goto [say Numbers 7]
instead of that path use:
on {timeout 0} goto [say Numbers 7]
and you may also want to set the number or replays to 0, so that the module [say Numbers 8] only plays the number once.
Youi can also use some DTMF triggered paths - but caller then need to press keys on their telephone keypad in order for those paths to be taken.
