Guest force Report post Posted 02/04/2006 09:10 PM hi when write the oracle sql statment as select empno ,ename from emp where empno=444; if there is no empno = 444 the sql engine output this message 'no data found ' how to deal with this messag in Evaluate Expression module. is this message = null , 1.vgs Share this post Link to post
SupportTeam Report post Posted 02/04/2006 11:39 PM Could you please post a copy of VoiceGuide's Debug Printout which captures this sceanrio, this will allow us to see what happened. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. When posting traces/scripts please .ZIP them up and post them as attachements. Share this post Link to post
Guest Guest Report post Posted 02/06/2006 12:46 PM hi i attched 4 log files in the log1 succesd to retrive data , the log2 no data becaus the employe number 444 alredy not found in database schema, in log3 i write select statment ,it must be retrive data form schema , log4 the employe number 7934 already in database but the 444 wrong number log.zip Share this post Link to post
Guest force Report post Posted 02/06/2006 04:48 PM the log files and script log.zip Share this post Link to post
SupportTeam Report post Posted 02/06/2006 10:54 PM Use: ModuleTitle_RowCount This will return the number of entries which were returned. If no data was retried the RV above will hold the value of 0. Share this post Link to post
Guest force Report post Posted 02/07/2006 07:23 PM hi i already use ModuleTitle_RowCount for check the row count, but the same when input employe number 7788 the script sucess, if input empn=999 the script exit, attached scribt , s4,s5 log file t5.zip Share this post Link to post
SupportTeam Report post Posted 02/08/2006 09:41 AM Have you tried adding a fail path from the DBQuery module to the Evaluate expression module? If the database query does not get any results it looks for a fail path. If there is no fail path then VoiceGuide will end the call - which is what's happening here. Share this post Link to post
Guest force Report post Posted 02/08/2006 03:11 PM yes i know this what happen ! but the voice guide must be deal with no data retrived from database. so when the ModuleTitle_RowCount will equal to 0, Share this post Link to post
SupportTeam Report post Posted 02/08/2006 09:36 PM If the database query does not get any results it looks for a fail path. If there is no fail path then VoiceGuide will end the call - which is what's happening here. You must specify the 'fail' path if you want to handle a situation where no data is retrieved. Share this post Link to post
