Guest Jakub Gomula Report post Posted 02/06/2006 12:14 PM I try to make and register a conversation between two people with D/41 conference card. This works fine but only if the person dialed on seckend line will answer. If not (or line is busy) I can't redirect conversation to another line. How can I detect if line is unanswered or busy? Best Regards Jakub Gomula/Poland Share this post Link to post
Guest Jakub Gomula Report post Posted 02/07/2006 10:11 AM I have read old topics and reconfigured ConfigLine.xml. Now is working properly. Share this post Link to post
SupportTeam Report post Posted 02/08/2006 03:00 AM I assume what needed to be done here was the 'busy' and 'disconnect' tone definitions needed to be set correctly to match what is played by the local phone company, so that the Dialogic card can correctly detect when these tones are played... Instructions on how to set ConfigLine.xml to match these tones can be found here: http://www.voiceguide.com/vghelp/html/Disc...ctionDetect.htm Share this post Link to post
