Intel Ip Board Compatibility
I am looking at using the Intel DM/IP481-2T1-PCI-100BT board to connect back to an Avaya Definity G3 for connection over ethernet. Does your software support this type of board? Do you have any information on the architecture to connect back to an Avaya Definity G3?
The IP connectivity on this board is not officially supported at this stage - although in theory you should be able to enable it by just specifying the correct device names in the VoiceGuide for Dialogic's Config.xml file.
If you can give us access to this machine using PCAnywhere or WinVNC we can have a look at this machine and help you set this up. (send connection details to support@VoiceGuide.com, quoting this post)
You should have no troubles in getting the board to link up with the Definity using the T1 links (which there should be 2 of on the card).
Architecture would be fairly straightforward - you either need Ethernet connectivity to the Definity or T1 lines coming from it...
