Voiceguide No Longer Starting
After exiting the program to try an adjustment to our script this morning, I tried to restart the program, but it simply partly loads the GUI and then never fully starts up. I've rebooted the server a number of times, starting/restarting services and even resetting the script to an older, known working version. It has had no effect on the startup of the program. Is there something else I can do short of uninstalling and reinstalling, crossing my fingers, and hoping it works again?
Thanks.
This is a bit unusual. Can you give us more information about your system please. Hardware, speed, memory, etc.
We may be able to see in logs at which stage it pauses/stops.
In VG.INI set log levels to 10 and the start VG. logs will be created in Vg's \log\ subdirectory.
