bermuda Report post Posted 06/28/2003 04:43 AM Hi, I am trying to run a script once the call has finished - but it seems to be getting an error as you can see from the following code. Your help would be greatly appreciated. I have installed the latest 4.9.1 update along with the other file (as per a previous post). 72244 5 tapie linedevstate 2048 0 0 72244 5 tapie callstate OFFERING 65996 0 4 72254 5 Answer the call 72264 5 lineAnswer(65996) => 65979 72284 5 Lev_CallerID [0412051737,] 72324 5 tapie callinfo CALLEDID 72324 5 tapie callinfo ORIGIN 72334 5 tapie ring 0 72805 5 tapie callstate CONNECTED 65996,1,0 72815 5 WorkingModeTAPI= 72815 5 WorkingModeScript= 72825 5 Inband detection not enabled 72855 5 StartLoadedVgs start 72865 5 tapi Reply 65979 0 72865 5 [play_welcome] Playing 72865 5 tts generate start[Welcome to Shazam] 72865 5 tts generate end 72865 5 [play_welcome] Playing (C:\ivr\sound_files\welcome.wav) 73365 5 PlaySoundStart ok [C:\ivr\sound_files\welcome.wav] 73365 5 RunModule PLAY end 75328 5 wb(87287500) 75388 5 Play End line[5] (id=872875) 75408 5 LsPlayMsg EV_PLAY_FINISHED 75408 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 75418 5 [detect_CID] Evaluate [$RV_CIDNUMBER] 75418 5 RVreplace start: [$RV_CIDNUMBER] 75418 5 RVreplace end: [0412051737] 75428 5 .Eval(0412051737) 75458 5 Eval Expr result:[412051737] stored in $RV[CID_DETECTED] 75458 5 [convert_CID] Evaluate ["61" & right($RV_CIDNUMBER,9)] 75458 5 RVreplace start: ["61" & right($RV_CIDNUMBER,9)] 75468 5 RVreplace end: ["61" & right(0412051737,9)] 75468 5 .Eval("61" & right(0412051737,9)) 75478 5 Eval Expr result:[61412051737] stored in $RV[iCIDNUMBER] 75488 5 [get_call_details] Evaluate [year(date) & "-" & "$RV_MONTH-$RV_DAY-$RV_HOUR$RV_MINUTE"] 75488 5 RVreplace start: [year(date) & "-" & "$RV_MONTH-$RV_DAY-$RV_HOUR$RV_MINUTE"] 75488 5 RVreplace end: [year(date) & "-" & "6-6-1445"] 75488 5 .Eval(year(date) & "-" & "6-6-1445") 75498 5 Eval Expr result:[2003-6-6-1445] stored in $RV[CALL_DETAILS] 75498 5 [prepare_storage] Running vb script:[C:\ivr\ivr_scripts\system-P2HU_01.vgs] 94626 5 Loaded VbsAtHangup into:2 94686 5 ERROR 4.9.1 TW__LineEvCallState_Error:Subscript out of range 94686 5 tapi Reply 65962 0 Share this post Link to post
SupportTeam Report post Posted 06/28/2003 08:10 AM Please open "system-P2HU_01.vgs" in the script editor and set the script's start module using "Edit->Script Properties" menu. Having an old module name set as the "Starting Module" in the script would cause this error, as VoiceGuide does not now which module is the start module of the script. This problem with script may happen if an old start module is deleted from the script, and the new start module has not been explicitly set using the "Edit->Script Properties" menu. This issue is fixed in the 4.9.1 version of script editor onwards... Share this post Link to post
