Wscript.exe
For some reason, after our users hang up, there are multiple instances of wscript.exe running in the Task Manger. What is causing this? It is consuming a lot of resources.
Sounds like the VBScripts which you start from within Run VBScript module are not ending themselves. Best way to check which VBScripts are not ending themselves is to create cut-down versions of your VoiceGuide script which only call a selection of various VBScripts to track down which VBScripts are causing problems here.
