Run Module 2804 Hangsup Line
I am encountering a problem with my registered voiceguide
version.
the script i have worked for a while, but now it fails
and voiceguide hangsup, thanks to Run module 2804?
the script begins with a decision path depending upon
the caller id. it does one thing for personal calls,
another for unknown, and another for business say.
however it has begun to hangup the line right
after evaluationg the caller id expression (Who Calls).
Here is the event log -
Thanks - Vijay.
41843 0 tapie callstate OFFERING 66184 0 4
41843 0 tapie ring 1
43250 0 Lev_CallerID [8482191140,RAMAN]
47843 0 tapie ring 2
53843 0 tapie ring 3
53843 0 Start without answering the call
53843 0 [Who Calls] Evaluate [$RV_CIDNUMBER]
53843 0 RVreplace start: [$RV_CIDNUMBER]
53843 0 RVreplace end: [8482191140]
53843 0 .Eval(8482191140)
53875 0 Eval Expr result:[8482191140]
53875 0 HangupCall called from [Run module 2804]
53875 0 Hanging up call...
53875 0 HangupCall_Common Mode=BeforeAnswerRun
59843 0 tapie ring 4
71843 0 tapie callstate IDLE 66184 0 0
71843 0 WorkingMode@Idle=
71843 0 set EV_TIMEOUT_TIMETOREINITLINE 2
72906 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
72906 0 ReinitTelephony due to IDLE start
72906 0 tapic lineDeallocateCall(MainCall:66184) 0
74734 0 lineOpen(0) => 0
74734 0 Waiting for a call...
74734 0 lineOpen(0)LineHandle=66167
What are the paths leaving the module [Who Calls] ?
It looks like there are no defined paths leaving the module, and that is why VoiceGuide hangs up.
An 'Evaluate Expression" module should usually have at least two paths - "On True" and "On False" - and it looks like the "On True" path in [Who Calls] does not point to a valid module.
