Writing A Timestamp To A Text File
Hello.
I'm using the "Run Program" module to write to a .txt with the line you show on your help files:
command.com /c echo 15, $RV[fullname1], $RV[phone1] >> C:\output.txt
It works fine. However, I need to include on that line the exact time where it was written. How can I do that?
Thanks.
You may want to look into using VBScript to append the lines to the file.
VBScript will let you use the Now keyword/function to access the current time/date.
