Auto Cut Of Voice Guide Call And Not Play Sound
Hi
My incoming call is autocut and the default sound file cannot be play.
120734.92 5 linedevstate 2048 0 0
120734.92 5 callstate OFFERING 65781 0 4
120734.92 5 rv clear
120734.92 5 Answer the call at 3/1/2006 12:07:34 PM
120734.92 5 lineAnswer(65781) => 65798
120734.92 5 callinfo CALLEDID
120734.92 5 callinfo ORIGIN
120734.92 5 ring 0
120735.36 0 dial start any summary:|5:hc>0|
120735.45 5 callstate CONNECTED 65781 1 0
120735.45 5 callstate CONNECTED 65781,1,0
120735.47 5 WorkingModeTAPI@Connected=
120735.47 5 WorkingModeScript@Connected=
120735.47 5 Inband detection not enabled
120735.47 5 StartLoadedVgs at 3/1/2006 12:07:35 PM, v5.2.3063
120735.47 5 AddRVns [scriptsPath]{D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server\}
120735.47 5 AddRVns [scriptPath]{D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server}
120735.48 5 rv add [$RV_STARTTIME]{3/1/2006 12:07:35 PM}
120735.48 5 rv add [$RV_DEVICEID]{5}
120735.48 5 rv add [$RV_CIDNAME]{}
120735.48 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
120735.48 5 rv add [$RV_CIDNUMBER]{}
120735.48 5 tapi Reply (LineEvReply) ok 65798 0
120735.48 5 callinfo MONITORMODES
120735.48 5 timer clear
120735.48 5 [Welcome] Number Input
120735.48 5 [Welcome] Playing (VmailSysWelc.wav)
120735.48 5 play set playid=991343
120735.48 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server\VmailSysWelc.wav]
120735.50 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
120735.50 5 For Dialogic use: PCM 11Khz 8bit Mono
120735.50 5 rv add [Hangup Time]{3/1/2006 12:07:35 PM}
120735.50 5 Hanging up call... [srlib PlaySoundStart]
120735.50 5 RecSoundStop ok
120735.50 5 PlaySoundStop err=0
120735.50 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
120735.50 5 fnHangupCall end
120735.50 5 play end current play (playid=0)
120735.50 5 ScriptEventCode 8001 iLineState=900
120735.50 5 LsAwaitingCalls EV_PLAY_FINISHED
120735.52 5 ScriptEventCode 8001 iLineState=900
120735.52 5 LsAwaitingCalls EV_PLAY_FINISHED
120737.48 5 linedevstate 2048 0 0
120737.48 5 callstate IDLE 65781 0 0
120737.48 5 WorkingMode@Idle=
120737.48 5 timer clear
120737.48 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
120737.48 5 tapi Reply (LineEvReply) ok 66499 0
120738.55 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
120738.55 5 ScriptEventCode 9008 iLineState=900
120738.55 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
120738.55 5 ReinitTelephony due to IDLE
120738.55 5 tapic lineDeallocateCall(MainCall:65781) 0
120738.58 5 lineOpen(5)=>
120738.58 5 Waiting for a call...
120738.58 5 LineHandle=65730
120738.58 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
120739.36 0 dial start any summary:|5:rdy=0|
120741.86 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
120741.86 5 ScriptEventCode 9013 iLineState=900
120742.36 0 dial start any summary:|5:idx=0|
120759.64 5 linedevstate 2048 0 0
120759.66 5 ring 0
120810.50 5 linedevstate 2048 0 0
120811.50 5 linedevstate 1024 0 0
120811.52 5 linedevstate 512 0 0
120831.03 5 linedevstate 2048 0 0
120831.03 5 callstate OFFERING 65678 0 4
120831.03 5 rv clear
120831.03 5 Answer the call at 3/1/2006 12:08:31 PM
120831.05 5 lineAnswer(65678) => 66089
120831.05 5 callinfo CALLEDID
120831.05 5 callinfo ORIGIN
120831.05 5 ring 0
120831.36 0 dial start any summary:|5:hc>0|
120831.58 5 callstate CONNECTED 65678 1 0
120831.58 5 callstate CONNECTED 65678,1,0
120831.58 5 WorkingModeTAPI@Connected=
120831.58 5 WorkingModeScript@Connected=
120831.59 5 Inband detection not enabled
120831.59 5 StartLoadedVgs at 3/1/2006 12:08:31 PM, v5.2.3063
120831.59 5 AddRVns [scriptsPath]{D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server\}
120831.59 5 AddRVns [scriptPath]{D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server}
120831.59 5 rv add [$RV_STARTTIME]{3/1/2006 12:08:31 PM}
120831.59 5 rv add [$RV_DEVICEID]{5}
120831.59 5 rv add [$RV_CIDNAME]{}
120831.59 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
120831.59 5 rv add [$RV_CIDNUMBER]{}
120831.59 5 tapi Reply (LineEvReply) ok 66089 0
120831.61 5 callinfo MONITORMODES
120831.61 5 timer clear
120831.61 5 [Welcome] Number Input
120831.61 5 [Welcome] Playing (VmailSysWelc.wav)
120831.61 5 play set playid=47468
120831.61 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [D:\Local_Server\VoiceGuide backup\Scripts\Voicemail Server\VmailSysWelc.wav]
120831.61 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
120831.61 5 For Dialogic use: PCM 11Khz 8bit Mono
120831.61 5 rv add [Hangup Time]{3/1/2006 12:08:31 PM}
120831.61 5 Hanging up call... [srlib PlaySoundStart]
120831.61 5 RecSoundStop ok
120831.63 5 PlaySoundStop err=0
120831.63 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
120831.63 5 fnHangupCall end
120831.63 5 play end current play (playid=0)
120831.63 5 ScriptEventCode 8001 iLineState=900
120831.63 5 LsAwaitingCalls EV_PLAY_FINISHED
120833.61 5 linedevstate 2048 0 0
120833.61 5 callstate IDLE 65678 0 0
120833.61 5 WorkingMode@Idle=
120833.61 5 timer clear
120833.61 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
120833.61 5 tapi Reply (LineEvReply) ok 66243 0
120834.69 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
120834.69 5 ScriptEventCode 9008 iLineState=900
120834.69 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
120834.69 5 ReinitTelephony due to IDLE
120834.69 5 tapic lineDeallocateCall(MainCall:65678) 0
120834.72 5 lineOpen(5)=>
120834.72 5 Waiting for a call...
120834.72 5 LineHandle=66328
120834.72 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
120835.36 0 dial start any summary:|5:rdy=0|
120838.00 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
120838.00 5 ScriptEventCode 9013 iLineState=900
120838.36 0 dial start any summary:|5:idx=0|
120847.31 5 linedevstate 2048 0 0
120847.33 5 ring 0
120858.20 5 linedevstate 2048 0 0
120859.20 5 linedevstate 1024 0 0
120859.22 5 linedevstate 512 0 0
We see in trace file:
This is a common problem with some voice modems and with Dialogic's TAPI/Wave drivers.
Are you using a Dialogic card? If yes then you should be using "VoiceGuide for Dialogic".
