Rvset Variable Not In .vbs - Bad Logic By Me?
Hello,
Would someone look at my .vgs script? I can't figure out why I can't get a return value from an RvSet statement. Attached are the script, trace log, temp .vbs,
and a test vbs where the value IS returned.
Here is a snippet of my code:
'Script : Answer and Record.vgs
'Module : RecordCall?
'Description: Y/N MsgBox to ask whether to record conversation.
'Already chose to answer this call via previous module ValidIDAlert or InvalidIDAlert
if msgbox("Record Conversation ?", vbYesNo + vbQuestion + vbDefaultButton2, "Record ?") = vbYes then
 vg.RvSet $RV_LINEID, "tRecord", "Record"
 'msgbox "Record Option was $RV[tRecord]" 'NOT returning value in VBS
 vg.Run_ResultReturn $RV_DEVICEID, "yes"
else
 vg.RvSet $RV_LINEID, "tRecord", "NoRecord"
 vg.Run_ResultReturn $RV_DEVICEID, "no"
end if
'Add this to Call log even if I decide to answer the call myself
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("C:\VGCallLog.csv", ForAppending, True)
msgbox "Record Option was $RV[tRecord]" 'This Does NOT return a value
msgbox "Record Option was " & "$RV[tRecord]" 'This also Does NOT return a value
tsFile.WriteLine "$RV_STARTTIME,$RV_CALLLENGTH,$RV[tLineName],$RV_CIDNUMBER,$RV[tNumber],$RV[tCompany],$RV[tRecord]"
'above csv file leaves the column for tRecord empty
tsFile.Close
set tsFile = Nothing
set fso = Nothing
set vg = Nothing
The correct value does show up in the trace log . . .
134359.73   0 cl    RvSet tRecord, NoRecord
134359.73   0 rv    lg add [tRecord]{NoRecord}
134359.73   0 cl    Run_ResultReturn >>no<<
134359.73   0 rv    lg add [RecordCall?_ResultReturn]{no}
134359.73   0 cl    module's runwait=1, WavPlayHasNowFinished=0
. . .but not in anything else.
Is my logic incorrect? The module works fine except for the $RV[tRecord] value.
Thanks,
Chris
TraceLog_and_Support_Files.zip
The $RV[myRvName] placeholders are processed and replaced with the RV values before the VBScript is ran.
So you cannot set the RV in the VBScript using .RvSet() and then use a placeholder $RV[myRvName] to access the RV in the same script. The $RV[myRvName] is not defined at time of placeholder replacement, so the placeholder will be replaced by an empty string.
You still may use RvGet, but there is no need really... you already have the value available to you in the script - you've jsut used it in the RvSet call... so there is no need to use an RV to access tha value anyway...
I see. My RvSet value isn't being assigned until midway through the vbScript.
You still may use RvGet, but there is no need really... you already have the value available to you in the script - you've just used it in the RvSet call... so there is no need to use an RV to access tha value anyway...
I need to write that value into the log file. The value is dependent on whether I answer yes or no in the message box.
Are you saying that this line should not be in the same module? . . . Or are you saying I should use a different syntax of writing $RV[tRecord] into the log file?
Sorry if this is a dumb question, I'm picking up the vbs scripting pretty quick, but it took several days of trial & error to get correct results from RvSet, RvSet_RvList, RvGet objects.
Still, the learning part is quite exciting.
Store the value you are assigning to $RV[tRecord] in another varaible and just use that variable when creating your string to save in log file....
Something like this (changed lines in bold)
sActionToTake = "Record"
vg.RvSet $RV_LINEID, "tRecord", sActionToTake
else
sActionToTake = "NoRecord"
end if
msgbox "Record Option was " & sActionToTake
tsFile.WriteLine "$RV_STARTTIME,$RV_CALLLENGTH,$RV[tLineName],$RV_CIDNUMBER,$RV[tNumber],$RV[tCompany]," & sActionToTake
tsFile.Close
set fso = Nothing
set vg = Nothing
Well, that sure solved the problem!
It sounds so simple when you say it. Thanks for taking the time to actually write the lines, I really appreciate it. I'm mostly learning by following examples.
I just learned two things:
. . . tells me to try using an assigned variable in some cases to RvSet if I am having trouble with a particular RV.
. . . was having some troubles in the past using variables writing out to a file (mostly just syntax). This helps alot.
Your help file also has plenty of examples, including good links to vbs functions. That's where I'm going now. . . .
Thanks again,
Chris
