Time Evaluate
I need to collect an arrival time from my callers. I'd like to collect it as a 3 or 4 digit time, plus a variable for AM/PM.
Then I would like to use the "Say Numbers" module to read back the entry in a "Time HHNN" format.
I am collecting two variables:
ArriveT1 = 3 or 4 digit time (i.e. 915 or 1123)
ArriveT2 = 1 digit AM/PM indicator (1=AM, 2=PM)
I would like to have an "Evaluate Expression" module manipulate the input variables to pass a new variable to the "say Numbers" module. I have tried the following:
$RV[ArriveT1] + 1200*($RV[ArriveT2]-1)
This is failing when it gets to the repeat module, and is not saving the evaluated number in the logs. I also think that I may have to pad a time before 10:00 with a leading 0, as the say module in "Time HHNN" mode will not accept a simple 959, but needs a 0959 to play.
HELP!
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
That is correct - right now you will need to also evaluate whether $RV[ArriveT1] <1000 and if it is then another evaluate module can be used to prepend a "0". (v4.9.1 onwards can accept 3 digit hours for "Time HHNN" playing).
It may be easier to write a short VB Script to do all of the above instead of a series of Evaluate Expression modules...
