Voicemail Server Problem
Hello, i have a problem with Voicemail Server.
Before reinstalling Windows, VG VMS works fine. I've copy all settings+scripts+voicemail boxes before reinstallation of Windows and restore everything after. But now it's not able to handle incoming calls. Even installtation of VG without old settings does't work with voicemail script. After I'm trying to call to VG, system asking me '...Please enter 4 digit voicemail box number...' and after this VG repeat everything again. Again and again until droping connection.
VG - 5.2.5012 Enterprise Edition, one line license.
Is somewhere any step by step guide regarding such voicemail server setup or basic steps to get it up?
Does the voicemail box which you are entering exist? Check using the voicemail manager.
Yes, mailbox exists. Whey works fine bero windows reinstall. It's does't work even with boxes which installed as sample during new vg installtion.
Could you please post a copy of VoiceGuide's Debug Printout which captures the start of program and the call, this will allow us to see what happened.
When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - then select 'save to file'. Logs will be created in \log\ directory as well.
Restart VG and then make the call.
.ZIP all traces in \log\ subdirectory and post them as attachments.
In the .ZIP file include the VmBoxList.xml file from VG's \data\ subdirectory.
This is a trace
090010.13 0 tapi callstate start
090010.13 0 tapi callstate OFFERING 66083 0 4
090010.14 0 rv clear
090010.14 0 Answer the call at 3/8/2006 9:00:10 AM
090010.14 0 lineAnswer(66083) => 66066
090010.14 0 ring 1
090010.16 0 tapi callstate start
090010.16 0 tapi callstate ACCEPTED 66083 0 0
090010.16 0 dial start any summary:|0:hc>0|
090012.69 0 tapi Reply (LineEvReply) ok 66066 0
090012.69 0 tapi callstate start
090012.70 0 tapi callstate CONNECTED 66083 0 0
090012.70 0 callstate CONNECTED 66083,0,0
090012.70 0 WorkingModeTAPI@Connected=
090012.70 0 WorkingModeScript@Connected=
090012.72 0 Inband detection not enabled
090012.72 0 StartLoadedVgs at 3/8/2006 9:00:12 AM, script interpretor VgMulti v5.2.5012 3
090012.72 0 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}
090012.75 0 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}
090012.75 0 rv lg add [$RV_STARTTIME]{3/8/2006 9:00:12 AM}
090012.77 0 rv lg add [$RV_DEVICEID]{0}
090012.77 0 rv lg add [$RV_CIDNAME]{}
090012.78 0 rv ns add [PathApp]{c:\Program Files\VoiceGuide\}
090012.78 0 rv lg add [$RV_CIDNUMBER]{}
090012.78 0 rv lg add [$RV_DNIS]{}
090012.80 0 rv lg add [DNIS]{}
090012.84 0 timer clear
090012.86 0 state [Welcome] Number Input
090012.86 0 state [Welcome] Playing (VmailSysWelc.wav)
090012.88 0 play set playid=354453
090013.05 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
090013.05 0 timer clear
090019.27 0 vm loading VMB data begin
090019.36 0 vm loading VMB data - about to delete old entries
090019.41 0 vm sort start on 56 entries.
090019.47 0 vm sort end.
090019.50 0 vm loading VMB data end
090019.52 0 Loaded new voicemail configuration file (XML)
090025.64 0 play end current play (playid=354453)
090025.64 0 ScriptEventCode 8001 iLineState=1300
090025.69 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
090025.72 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
090025.75 0 timer set 5 EV_TIMEOUT_REPLAYMSG
090031.11 0 timer fired EV_TIMEOUT_REPLAYMSG
090031.11 0 ScriptEventCode 9005 iLineState=1301
090031.14 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
090031.17 0 state [Welcome] Playing (VmailSysWelc.wav)
090031.19 0 play set playid=372765
090031.41 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
090031.42 0 timer clear
090043.41 0 play end current play (playid=372765)
090043.41 0 ScriptEventCode 8001 iLineState=1300
090043.45 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
090043.50 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
090043.52 0 timer set 5 EV_TIMEOUT_REPLAYMSG
090048.91 0 timer fired EV_TIMEOUT_REPLAYMSG
090048.91 0 ScriptEventCode 9005 iLineState=1301
090048.91 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
090048.95 0 state [Welcome] Playing (VmailSysWelc.wav)
090048.97 0 play set playid=390546
090049.17 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
090049.17 0 timer clear
090101.17 0 play end current play (playid=390546)
090101.17 0 ScriptEventCode 8001 iLineState=1300
090101.20 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
090101.22 0 timer set 10 EV_TIMEOUT_HANGUP
090101.28 0 timer set 6 EV_TIMEOUT_ENTERDATA
090107.75 0 timer fired EV_TIMEOUT_ENTERDATA
090107.75 0 ScriptEventCode 9006 iLineState=1301
090107.75 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
090107.80 0 rv lg add [Welcome]{}
090107.81 0 rv ns add [Welcome_PathTaken]{fail}
090107.84 0 voicemail used: Scripted
090107.86 0 stack idx=1
090107.94 0 rv lg add [scriptStart_Time]{3/8/2006 9:01:07 AM}
090107.97 0 rv lg add [scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}
090107.98 0 rv lg add [scriptStart_CalledFrom_Module]{Welcome}
090108.02 0 LoadedVgs_Find c:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=1
090108.05 0 rv ns add [scriptsPath]{c:\Program Files\VoiceGuide\system\vm\}
090108.05 0 rv lg add [PathSysVoice]{c:\Program Files\VoiceGuide\system\voice\}
090108.16 0 rv lg add [PathDataVm]{c:\Program Files\VoiceGuide\data\}
090108.16 0 rv lg add [PathVgSys]{c:\Program Files\VoiceGuide\system\}
090108.28 0 timer clear
090108.28 0 state [VmLoginStart] Running VB Script...
090108.34 0 rv replace start (strlen>500)
090108.38 0 rv ns [PathSysVoice]{c:\Program Files\VoiceGuide\system\voice\}[PathApp]{c:\Program Files\VoiceGuide\}[PathDataVm]{c:\Program Files\VoiceGuide\data\}[PathVgSys]{c:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}[$RV_STARTTIME]{3/8/2006 9:00:12 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{c:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Welcome]{}[Welcome_PathTaken]{fail}[scriptStart_Time]{3/8/2006 9:01:07 AM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}[scriptStart_CalledFrom_Module]{Welcome}[scriptsPath]{c:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{c:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{c:\Program Files\VoiceGuide\data\}[PathVgSys]{c:\Program Files\VoiceGuide\system\}
090108.47 0 eng run vbs [wscript "c:\Program Files\VoiceGuide\temp\vbs_0_1_0308090108.vbs" //I] copy of script in: vbs_0_1_0308090108.vbs
090108.66 0 Run Script waiting. iRunWait=1 (shellid=3940, process=976)
090108.67 0 timer set 1 EV_TIMEOUT_CHECKONSTATE
090108.83 0 cl Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMm
dminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminNa
e]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key
VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[
ey_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPla
MessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdm
nWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsg
aveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndP
ay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_Vm
endMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_Stop
ecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
090108.89 0 rv ns add [Key_VmMmNewMsgs]{1}
090108.92 0 rv ns add [Key_VmMmSavedMsgs]{2}
090108.97 0 rv ns add [Key_VmMmAdminGreeting]{3}
090109.02 0 rv ns add [Key_VmMmAdminPin]{4}
090109.05 0 rv ns add [Key_VmMmAdminForwardPhone]{5}
090109.06 0 rv ns add [Key_VmMmRecMessage]{6}
090109.13 0 rv ns add [Key_VmMmAdminName]{7}
090109.19 0 rv ns add [Key_VmMmGoVmLogin]{8}
090109.22 0 rv ns add [Key_VmMmVmExit]{0}
090109.25 0 rv ns add [Key_VmMmPlayMessageCounts]{#}
090109.27 0 rv ns add [Key_VmRmReplayCurrent]{1}
090109.34 0 rv ns add [Key_VmRmSaveAndPlayNext]{2}
090109.34 0 rv ns add [Key_VmRmDeleteAndPlayNext]{3}
090109.44 0 rv ns add [Key_VmRmPlayPrevious]{4}
090109.52 0 rv ns add [Key_VmRmPlayCurrent]{5}
090109.53 0 rv ns add [Key_VmRmPlayNext]{6}
090109.58 0 rv ns add [Key_VmRmPlayMessageInfo]{7}
090109.61 0 rv ns add [Key_VmRmGoVmLogin]{8}
090109.67 0 rv ns add [Key_VmRmExitRetrieveMessages]{0}
090109.73 0 rv ns add [Key_VmAdminWelcMsgPlayCurrent]{1}
090109.77 0 rv ns add [Key_VmAdminWelcMsgDeleteAndRecNew]{2}
090109.80 0 rv ns add [Key_VmAdminWelcMsgSaveAndReturn]{3}
090109.81 0 rv ns add [Key_VmAdminWelcMsgDeleteAndReturn]{4}
090109.86 0 rv ns add [Key_VmSendMsg_StopRecAndPlay]{1}
090109.89 0 rv ns add [Key_VmSendMsg_DelRecAndRec]{2}
090109.94 0 rv ns add [Key_VmSendMsg_SaveRecAndAddress]{3}
090109.98 0 rv ns add [Key_VmSendMsg_DelRecAndReturn]{4}
090109.98 0 rv ns add [Key_VmSendMsg_DelRecAndReturn2]{0}
090110.05 0 rv ns add [Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}
090110.06 0 rv ns add [VmbId]{}
090110.08 0 rv ns add [VmbLoginIntro]{none}
090110.09 0 cl module's runwait=1, WavPlayHasNowFinished=0
090110.17 0 timer clear
090110.19 0 state [VmLoginAskVmb] Number Input
090110.25 0 rv replace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
090110.27 0 rv ns [PathSysVoice]{c:\Program Files\VoiceGuide\system\voice\}[PathApp]{c:\Program Files\VoiceGuide\}[PathDataVm]{c:\Program Files\VoiceGuide\data\}[PathVgSys]{c:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}[$RV_STARTTIME]{3/8/2006 9:00:12 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{c:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Welcome]{}[Welcome_PathTaken]{fail}[scriptStart_Time]{3/8/2006 9:01:07 AM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}[scriptStart_CalledFrom_Module]{Welcome}[scriptsPath]{c:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{c:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{c:\Program Files\VoiceGuide\data\}[PathVgSys]{c:\Program Files\VoiceGuide\system\}[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_V
MmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdmi
Name]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[
ey_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{
}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRm
layMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_Vm
dminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelc
sgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecA
dPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key
VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_S
opRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}
090110.31 0 rv replace end: [none,c:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav]
090110.36 0 state [VmLoginAskVmb] Playing (none,c:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav)
090110.39 0 play set playid=411968
090110.64 0 PlaySoundStart ok [c:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav]
090110.64 0 timer clear
090115.75 0 play end current play (playid=411968)
090115.81 0 ScriptEventCode 8001 iLineState=1300
090115.81 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
090115.89 0 eng set timer EV_TIMEOUT_REPLAYMSG time=4
090115.92 0 timer set 4 EV_TIMEOUT_REPLAYMSG
090120.03 0 dtmf # (66083,35,2)
090120.06 0 ScriptEventCode 35 iLineState=1301
090120.09 0 LsGetNbrsRxDigits #
090120.13 0 timer clear
090120.16 0 rv lg add [VmLoginAskVmb]{}
090120.19 0 rv ns add [VmLoginAskVmb_PathTaken]{fail}
090120.19 0 rv lg add [Hangup Time]{3/8/2006 9:01:20 AM}
090120.23 0 state Hanging up call... [Ls GetNbrsRxDigit]
090120.28 0 RecSoundStop ok
090120.44 0 PlaySoundStop err=0
090120.45 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
090120.58 0 fnHangupCall end
090120.69 0 tapi callstate start
090120.69 0 tapi callstate DISCONNECTED 66083 1 0
090120.73 0 ScriptEventCode 9250 iLineState=900
090120.77 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
090120.80 0 rv lg add [Hangup Time]{3/8/2006 9:01:20 AM}
090120.80 0 state Hanging up call...
090120.91 0 RecSoundStop ok
090120.98 0 PlaySoundStop err=0
090121.06 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
090121.11 0 fnHangupCall end
090121.16 0 tapi callstate start
090121.19 0 tapi callstate IDLE 66083 0 0
090121.27 0 WorkingMode@Idle=
090121.28 0 timer clear
090121.38 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
090121.38 0 tapi Reply (LineEvReply) ok 66134 0
090121.45 0 tapi Reply (LineEvReply) ok 66117 0
090122.44 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
090122.45 0 ScriptEventCode 9008 iLineState=900
090122.48 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
090122.50 0 ReinitTelephony due to IDLE
090122.56 0 tapic lineDeallocateCall(MainCall:66083) 0
090122.77 0 lineOpen(0)=>
090122.77 0 state Waiting for a call...
090122.81 0 LineHandle=66151
090122.92 0 amchk set AMdet=False in Reinit@idle
090122.95 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
090123.56 0 dial start any summary:|0:rdy=0|
090126.25 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
090126.28 0 ScriptEventCode 9013 iLineState=900
090126.58 0 dial start any summary:|0:idx=0|
Log folder with VmBoxList.xml attached
log.zip
Trace shows that caller when asked to select the voicemail box number for which to leave a message just pressed "#" instead of entering the number...
Do you want the caller to be directed to a particular mailbox without them selecting anything? or just upon them pressing # ? If yes the you should modify the script top do that...
The default "Voicemail Server" script that ships with VG asks caller to enter the vmb number.
Maybe you were using some other script beforehand?
I have restored voicemail server script which works before. I cheked it many times.
The '#' key was pressed just as attempt to look at action of vg.
I want the caller to be directed to a particular mailbox after entering extention number.
But the trace shows that the caller did not press any keys to select any mailbox... you can see this in the trace yourself... and they were asked twice to enter it. (once in module [Welcome] in Voicemail Server.vgs, and next time in module [VmLoginAskVmb] in VmLogin.vgs)
If the caller presses the keys on their telephone keypad to enter the number of an existing mailbox number then they will be taken to it...
That's why i'm asking you help with basic setup of voicemail server.
I'm calling to vg -> vg telling me 'Welcome to vg voicemail system...' -> I'm pressing the buttons with extention number, for example '0059' -> vg telling 'Welcome to vg voicemail system...'. Again and again... The program detect only star key properly.
OK, so looks like your real problem is that the system is not detecting DTMF tones properly...
Are you using a voice modem? Many voice modems have problems detecting DTMF tones or detect tones incorrectly.
It's the telephony card or voice modem that is responsible for detecting a DTMF tone and then sends a message to VG informing it that a particular tone has been heard on the line.
Trace shows that VG has only received an indication that # was pressed, and the script reacted as expected if caller presses # at that time.
I'm currently use BCM V.92 65K Voicemodem.
All computer hardware still the same as it was before, except hdd. Reinstalling of drivers don't make sense.
