bear007 Report post Posted 03/08/2006 04:11 AM My company is using DID (direct in dialing) service with 100 numbers from Telecom and would like to setup five to ten voice mails with different scripts. Please kindly advise the possibility of using DID with VG. Thanks. Share this post Link to post
SupportTeam Report post Posted 03/08/2006 04:38 AM VoiceGuide does support DID. It's value can be accessed throughout the scripts using the $RV_DNIS Result Variable. Sounds like you are using an ISDN T1 or E1 line? Share this post Link to post
bear007 Report post Posted 03/08/2006 06:15 AM Really thanks for your prompt response. Yes, it is an E1 line. My next question is how to connect my computer with an E1 line. What kind of hardware I have to purchased? Any good and low cost suggestion? Also, is there any maximum limit of the number of mail box in VG? Share this post Link to post
SupportTeam Report post Posted 03/08/2006 06:24 AM What kind of hardware I have to purchased? Dialogic (Intel) D/300JCT card. Also, is there any maximum limit of the number of mail box in VG? Not really. The default "XML-Database" approach used by scripts will start slowing down at about 5000, but you can easily adapt the voicemail scripts to use MS-SQL or My-SQL or any other DB as the voicemailbox info store, and then the amount of mailboxes is pretty much infinite. Share this post Link to post
bear007 Report post Posted 03/08/2006 08:01 AM 1) what is the price of Dialogic (Intel) D/300JCT card? 2) Can I order it in Hong Kong (China)? 3) How about the software license If I have the VG installed with a E1 with 100 DID numbers? It is counted by DID number or the number of voice mail? Share this post Link to post
SupportTeam Report post Posted 03/08/2006 08:52 PM 1) what is the price of Dialogic (Intel) D/300JCT card? If you want a brand new card then you should contact Intel/Dialogic resellers. Many used cards are available on Ebay and here: http://www.thetelecomlink.com We sell new cards as well - send and email to sales@VoiceGuide.com to get the price. 3) How about the software license If I have the VG installed with a E1 with 100 DID numbers? It is counted by DID number or the number of voice mail? Neither. It is licensed for the number of lines used (ie: 30 is using a single E1) and the number of DIDs and voicemail boxes is not limited. Share this post Link to post
