Script Editor Scroll Bar Erratic Movement
Dear support,
The contents of the script editor window move erratically when scrolling. This has been reported a number of times in the forum, but I have seen no resolution or workaround mentioned.
I have upgraded to V5 on two systems, and installed on a new system, and consistently see the problems on all these W2000 systems.
Is there any progress on sorting out this problem which is very distracting and counter-productive? Is it script related? Would you like a copy of the scripts?
Regards.......VB
The occasional excessive scrolling of the screen seems to occur on slower computers only in conjunction with larger scripts. There is no fix available for this at this stage.
The problem should not occur if you drag the scroll position indicators themselves to the required position, rather then clicking the arrows at the ends of the scroll position indicator.
