Announced Call Transfers Not Completing
Janne Tykka wrote:
We would like to ask you a question. Conserning about calltransfers.
Voice guide does the transfers just fine until the call is answered. when we
answer the call it won´t connect. and on the other end of the line it just
keeps playing the ringing tone.
So what we are trying to do is a double transfer.. when the first transfer
is not answered it transfers to another number. It transfers the first call
just fine and the second, but we are not able to answer. when we answer the
call we hear nothing. and as I said the other end just hears the ringing
tone.. I would be pleased if you had any idea what I should do. we are
using a modem blaster 56k ext. in win2k. we have also spoken with our pbx
about this problem and they didn´t really know how to help. Here is our
event trace log.
73766 0 tapie callstate OFFERING 66409 0 4
73776 0 tapie ring 1
78773 0 tapie ring 2
78773 0 Answer the call
78773 0 lineAnswer(66409) => 66187
78773 0 tapie callstate ACCEPTED 66409 0 0
79014 0 tapi Reply 66187 0
79014 0 tapie callstate CONNECTED 66409,0,0
79014 0 WorkingModeTAPI=
79014 0 WorkingModeScript=
79014 0 Inband detection not enabled
79024 0 [Alku] Playing
79024 0 [Alku] Playing (C:\macodiili_ronkainen_maximize.wav)
79575 0 PlaySoundStart ok [C:\macodiili_ronkainen_maximize.wav]
79585 0 RunModule PLAY end
82979 0 tapie monitordigits 49 2
82979 0 LsPlayMsg [1]
84051 0 PlaySoundStop ok
84462 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
84462 0 [Testi] Announced Transfer to 0503026093 (Generate)
84472 0 tapic lineGenerateDigits(66409,!) => 0
84592 0 tapie generate LINEGENERATETERM_DONE
85573 0 LsXferStart EV_TAPI_GENERATE
86585 0 LsXferPlayVts EV_HOOKFLASHFINISHED
86585 0 tapic lineGenerateDigits(66409,0503026093) => 0
88668 0 tapie generate LINEGENERATETERM_DONE
89599 0 LsXferPlayVts EV_TAPI_GENERATE
89599 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
89609 0 twcal PlaySayNumber C:\Program
Files\VoiceGuide\system\voice\TsfrCallFrom.wav, C:\Program
Files\VoiceGuide\system\voice\TsfrAskAccept.wav, , , 1
89669 0 PlaySoundStartNumbers ok
96779 0 Play End line[0] (id=789619)
96789 0 LsXferPlayAnn EV_PLAY_FINISHED
96799 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
96799 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
96809 0 twcal PlaySayNumber C:\Program
96859 0 PlaySoundStartNumbers ok
03980 0 Play End line[0] (id=796819)
03990 0 LsXferPlayAnn EV_PLAY_FINISHED
04000 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
04000 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
04010 0 twcal PlaySayNumber C:\Program
04070 0 PlaySoundStartNumbers ok
11180 0 Play End line[0] (id=804020)
11190 0 LsXferPlayAnn EV_PLAY_FINISHED
11200 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
11200 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
11210 0 twcal PlaySayNumber C:\Program
11270 0 PlaySoundStartNumbers ok
18380 0 Play End line[0] (id=811220)
18390 0 LsXferPlayAnn EV_PLAY_FINISHED
18400 0 LsXferPlayAnn EV_PLAY_FINISHED
18400 0 tapic lineGenerateDigits(66409,!) => 0
18541 0 tapie generate LINEGENERATETERM_DONE
19512 0 LsXferPlayAnn EV_TAPI_GENERATE
19522 0 PlayFinishCause=CallRejected
19522 0 Going down Fail path (iXferType=1)
19933 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
19943 0 [testi2] Announced Transfer to 0503026093 (Generate)
19943 0 tapic lineGenerateDigits(66409,!) => 0
20063 0 tapie generate LINEGENERATETERM_DONE
21054 0 LsXferStart EV_TAPI_GENERATE
22066 0 LsXferPlayVts EV_HOOKFLASHFINISHED
22066 0 tapic lineGenerateDigits(66409,0503026093) => 0
24149 0 tapie generate LINEGENERATETERM_DONE
25080 0 LsXferPlayVts EV_TAPI_GENERATE
25080 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
25090 0 twcal PlaySayNumber C:\Program
25150 0 PlaySoundStartNumbers ok
32260 0 Play End line[0] (id=825100)
32270 0 LsXferPlayAnn EV_PLAY_FINISHED
32280 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
32280 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, ,
Digits
32290 0 twcal PlaySayNumber C:\Program
32350 0 PlaySoundStartNumbers ok
33021 0 tapie monitordigits 49 2
33021 0 LsXferPlayAnn [1]
34894 0 PlaySoundStop ok
35805 0 LsXferPlayAnn EV_PLAY_FINISHED
35815 0 tapic lineGenerateDigits(66409,!4) => 0
36146 0 tapie generate LINEGENERATETERM_DONE
37117 0 LsXferPlayAnn EV_TAPI_GENERATE
37127 0 PlayFinishCause=CallAccepted
37127 0 Success path not defined - hanging up (iXferType=1)
38139 0 LsXferPlayAnn EV_TIMEOUT_HANGUP
38149 0 PlaySoundStop ok
38149 0 HangupCall called from []
38159 0 Hanging up call...
38159 0 PlaySoundStop ok
38169 0 fnHangupCall end
39351 0 tapie callstate DISCONNECTED 66409,1,0
39351 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
39361 0 PlaySoundStop ok
39361 0 HangupCall called from []
39371 0 Hanging up call...
39381 0 PlaySoundStop ok
39381 0 fnHangupCall end
39391 0 tapie callstate IDLE 66409 0 0
39391 0 WorkingMode@Idle=
39401 0 set EV_TIMEOUT_TIMETOREINITLINE 2
39411 0 tapi Reply 66529 0
39421 0 tapi Reply 66392 0
40322 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
40322 0 ReinitTelephony due to IDLE start
40332 0 tapic lineDeallocateCall(MainCall:66409) 0
40362 0 lineOpen(0) => 0
40362 0 Waiting for a call...
40372 0 lineOpen(0)LineHandle=66426
43717 0 tapie callstate OFFERING 66255 0 4
43727 0 tapie ring 1
49755 0 tapie ring 2
49765 0 Answer the call
49765 0 lineAnswer(66255) => 66238
49776 0 tapie callstate ACCEPTED 66255 0 0
50046 0 tapi Reply 66238 0
50056 0 tapie callstate CONNECTED 66255,0,0
50056 0 WorkingModeTAPI=
50066 0 WorkingModeScript=
50076 0 Inband detection not enabled
50076 0 [Alku] Playing
50086 0 [Alku] Playing (C:\macodiili_ronkainen_maximize.wav)
50326 0 PlaySoundStart ok [C:\macodiili_ronkainen_maximize.wav]
50326 0 RunModule PLAY end
55384 0 tapie callstate DISCONNECTED 66255,1,0
55384 0 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
56245 0 PlaySoundStop ok
56255 0 HangupCall called from []
56255 0 Hanging up call...
56265 0 PlaySoundStop ok
56265 0 fnHangupCall end
57447 0 tapie callstate IDLE 66255 0 0
57457 0 WorkingMode@Idle=
57467 0 set EV_TIMEOUT_TIMETOREINITLINE 2
57467 0 tapi Reply 66273 0
58378 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
58378 0 ReinitTelephony due to IDLE start
58388 0 tapic lineDeallocateCall(MainCall:66255) 0
58418 0 lineOpen(0) => 0
58418 0 Waiting for a call...
58428 0 lineOpen(0)LineHandle=66000
Best regards
Janne Tykka
Macoline Oy
Janne Tykka wrote:
the recipient hears "press 1 to accept the call". but after that there
is nothing but silence.. and the caller just hears the ringing tone all the
way during the transfers. we have done some changes with our pbx to our
phone lines just for testing. and they
have now configured our lines as it were earlier when the announced transfer
was working. maybe we should try other settings with our pbx? because
earlier the modem could handle transfers just fine and now there have been
these strange problems.
The trace show that at no stage the modem reports that it has heard the
recipient press '1'....
If the recipient of call does press 1 then this means the modem cannot
detect those tone very well - the only solution is to try using a different
modem, or a different telephone handset at the recipient's extension (or
both).
You mention that before the call transfers worked fine, were the calls transferred to the same extension and using the same modem?
