Guest fsoudbakhsh Report post Posted 03/16/2006 11:44 PM I am trying to write a program to get the status of all my lines controlled by VG. If all lines are busy, I want to announce to my customers to try their call later on. Is it possible to get the result variable from VG to get the status of all the lines? Share this post Link to post
SupportTeam Report post Posted 03/17/2006 12:48 AM In VG for Dialogic you can use the function Line_State_CallState eg: set vg = CreateObject("VoiceGuide.CommandLink") strState = vg.Line_State_CallState($RV_LINEID) set vg = Nothing You would need to cycle through all the lines to get all the states for different lines. If you need to get the state for all the lines at the same time using one call then this would need to be added to the software for you. If you are interested in getting that done send and email to sales@VoiceGuide.com referencing this thread and someone will issue you a quote for the work. Share this post Link to post
