Caller Id
hello since i upgrade to version 6.0.2322 prof vg dialer line licence , i cannot get caller id any more , i use a D41EPCI with 3 analog lines , i think i made 3rings before answears to get id but i get nothing in log
thanks
184310,23 1 event callstate OFFERING 1 2,0,0
184310,38 1 script interpretor: VgMulti v6.0.2322
184310,38 1 fired OFFERING event to listeners
184310,39 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
184310,41 1 cid CallerID vars set (in 'offering' event) [,,]
184310,42 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
184310,42 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
184310,44 1 tw ring 1
184310,45 1 ring time since last ring event (sec): 0,00
184310,45 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
184310,47 1 answer as number of rings reached
184310,48 1 rv clear all
184310,50 1 init LineState ResetAtStartOfNewCall.
184310,53 1 start without answering the call
184310,55 1 StartLoadedVgs at 24/03/2006 18:43:10 [VgMulti v6.0.2322]
184310,61 1 set LineState().iVgsIdx=1
184310,63 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
184310,64 1 init StartLoadedVgs_InitLineState start
184310,66 1 rv add [$RV_STARTTIME]{24/03/2006 18:43:10}
184310,77 1 rv add [$RV_DEVICEID]{1}
184310,78 1 rv add [$RV_CIDNAME]{}
184310,80 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
184310,81 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\call recorders\lom\}
184310,83 1 rv add [$RV_CIDNUMBER]{}
184310,88 1 fn RunModule start
184310,89 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
184310,91 1 event ScriptEventCode TDX_CST, code=134, state=6001
184311,00 1 timer clear
184311,02 1 timer clear
184311,72 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
184311,73 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
184311,75 1 event callstate CONNECTED 1 256,0,0
184311,78 1 LineEvCallState_Connected hDevice=1 params=256,0,0
184311,80 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
184311,81 1 Inband detection not enabled
184311,83 1 fn RunModule start
184311,86 1 tw DialogicEvent 134,TDX_CST,37761,0,0,DE_LCON,,
184311,88 1 event ScriptEventCode TDX_CST, code=134, state=6001
184311,91 1 timer clear
184311,92 1 timer set 2 EV_TIMEOUT_READYTOBEGINTRANSFER
184314,08 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
184314,09 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
184314,11 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
184314,14 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
184314,16 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
184314,19 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
184314,20 1 state [Transfer to Fax Ext] Monitored Dial and Connect to 0603690969
184314,23 0 dial search for free lines in LineID range [0-4]
184314,25 1 dial busy: ReadyToDialout=0
184314,27 2 dial reserving: no list specified
184314,30 1 dial found free dev=2 (LineId=2) in XferDialAndConference
184314,31 1 state [Transfer to Fax Ext] Playing (C:\Program Files\VoiceGuide\Scripts\Internet Portal\IpOnHold.wav)
184314,33 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Internet Portal\IpOnHold.wav
184314,36 1 timer clear
184314,42 2 state dialing 0603690969 (for conference with dxxxB1C1)
184314,45 2 lineMakeCall(0603690969,DX_PAMDOPTEN) => 0
184314,47 2 call progress option selected: Voice or Answering Machine is detected. Listen for disconnect tones. (DX_PAMDOPTEN)
184314,50 2 using vg.ini [PBX] DialAndConf_MaxTalkTime_Default=3600
184314,53 1 timer set 3600 EV_TIMEOUT_HANGUP
184314,55 2 timer set 3600 EV_TIMEOUT_HANGUP
184314,56 1 tw wav->vox convert end 355031,C:\Program Files\VoiceGuide\Scripts\Internet Portal\IpOnHold.vox,1,0,,
184314,67 1 play start ok, lPlayId=355328
184314,98 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
184315,02 2 event ScriptEventCode TDX_SETHOOK, code=135, state=1922
184315,03 2 LsXfer_6_dc_WaitOutcomeOutgoingCall_DialingSide : 135,[TDX_SETHOOK],0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
184315,05 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : [TDX_SETHOOK], 135(EV_UNKNOWN_135),0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
184315,06 1 path {tdx_sethook} not found
184315,23 2 tw DialogicEvent 134,TDX_CST,38095,0,0,DE_LCON,,
184315,25 2 event ScriptEventCode TDX_CST, code=134, state=1922
184315,28 2 LsXfer_6_dc_WaitOutcomeOutgoingCall_DialingSide : 134,[TDX_CST],38095,0,0,DE_LCON,,
184315,30 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : [TDX_CST], 134(EV_UNKNOWN_134),38095,0,0,DE_LCON,,
184315,31 1 path {tdx_cst} not found
184329,38 2 tw DialogicEvent 133,TDX_CALLP,10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
184329,39 2 event ScriptEventCode VOICE, code=133, state=1922
184329,41 2 LsXfer_6_dc_WaitOutcomeOutgoingCall_DialingSide : 133,[VOICE],10,3,0,CR_CNCT,CON_PVD,
184329,42 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : [VOICE], 133(EV_UNKNOWN_133),10,3,0,CR_CNCT,CON_PVD,
184329,44 1 TwoCalls_Bridge as event indicates CR_CNCT
184329,48 2 conf TwoCalls_Bridge 2<=>1 (dxxxB1C2<=>dxxxB1C1)
184329,50 2 rvns add [TsRoutedTo]{1}
184329,52 1 rvns add [TsRoutedTo]{2}
184329,53 1 rvns add [Conf_DevName_1]{dxxxB1C2}
184329,55 1 rvns add [Conf_LineId_1]{1}
184329,58 1 rv add [Conf_DevName_2]{dxxxB1C1}
184329,59 1 rv add [Conf_LineId_2]{2}
184329,61 2 rvns add [Conf_DevName_1]{dxxxB1C2}
184329,63 2 rvns add [Conf_LineId_1]{1}
184329,64 2 rv add [Conf_DevName_2]{dxxxB1C1}
184329,66 2 rv add [Conf_LineId_2]{2}
184329,67 2 TsRoute dxxxB1C2<=>dxxxB1C1 call
184329,84 2 TsRoute dxxxB1C2<=>dxxxB1C1 SC_FULLDUP:
184329,86 2 state [] bridged with dxxxB1C1
184329,88 1 state [] outgoing leg, bridged with dxxxB1C2
184329,89 1 path {voice} not found
184329,91 2 event ScriptEventCode CONNECT, code=133, state=1911
184329,94 2 LsXfer_8_WaitEndCall_DialingSide : 133(), [CONNECT], 10,3,0,CR_CNCT,CON_PVD,
184329,95 1 LsXfer_8_WaitEndCall_RequestXferSide : 133(EV_UNKNOWN_133),connect,10,3,0,CR_CNCT,CON_PVD, (iModuleIdx=1)
184329,97 1 path {connect} not found
184329,98 2 event ScriptEventCode CON_PVD, code=133, state=1911
184330,03 2 LsXfer_8_WaitEndCall_DialingSide : 133(), [CON_PVD], 10,3,0,CR_CNCT,CON_PVD,
184330,06 1 LsXfer_8_WaitEndCall_RequestXferSide : 133(EV_UNKNOWN_133),con_pvd,10,3,0,CR_CNCT,CON_PVD, (iModuleIdx=1)
184330,11 1 path {con_pvd} not found
184330,13 2 event ScriptEventCode CR_CNCT, code=133, state=1911
184330,14 2 LsXfer_8_WaitEndCall_DialingSide : 133(), [CR_CNCT], 10,3,0,CR_CNCT,CON_PVD,
184330,17 1 LsXfer_8_WaitEndCall_RequestXferSide : 133(EV_UNKNOWN_133),cr_cnct,10,3,0,CR_CNCT,CON_PVD, (iModuleIdx=1)
184330,19 1 path {cr_cnct} not found
184330,20 2 event ScriptEventCode TDX_CALLP, code=133, state=1911
184330,23 2 LsXfer_8_WaitEndCall_DialingSide : 133(), [TDX_CALLP], 10,3,0,CR_CNCT,CON_PVD,
184330,25 1 LsXfer_8_WaitEndCall_RequestXferSide : 133(EV_UNKNOWN_133),tdx_callp,10,3,0,CR_CNCT,CON_PVD, (iModuleIdx=1)
184330,28 1 path {tdx_callp} not found
184330,81 1 tw PlayEnd 1 355328
184330,83 1 play end id=355328, (current ID)
184330,84 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1910
184330,86 1 LsXfer_8_WaitEndCall_RequestXferSide : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, (iModuleIdx=1)
184330,89 1 path {ev_play_finished} not found
184330,91 1 tw DialogicEvent 129,TDX_PLAY,355328,0,0,,,
184330,92 1 event ScriptEventCode TDX_PLAY, code=129, state=1910
184330,94 1 LsXfer_8_WaitEndCall_RequestXferSide : 129(EV_UNKNOWN_129),TDX_PLAY,355328,0,0,,, (iModuleIdx=1)
184330,95 1 path {tdx_play} not found
184337,78 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_LCOF,,
184337,80 1 event ScriptEventCode DE_LCOF, code=134, state=1910
184337,83 1 LsXfer_8_WaitEndCall_RequestXferSide : 134(EV_UNKNOWN_134),DE_LCOF,0,0,0,DE_LCOF,, (iModuleIdx=1)
184337,84 1 path {de_lcof} not found
184337,86 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_LCOF,,
184337,88 2 event ScriptEventCode DE_LCOF, code=134, state=1911
184337,89 2 LsXfer_8_WaitEndCall_DialingSide : 134(), [DE_LCOF], 0,0,0,DE_LCOF,,
184337,91 1 LsXfer_8_WaitEndCall_RequestXferSide : 134(EV_UNKNOWN_134),de_lcof,0,0,0,DE_LCOF,, (iModuleIdx=1)
184337,92 1 path {de_lcof} not found
184424,39 0 btn Hangup on line 1
184424,41 1 event ScriptEventCode EV_TIMEOUT_HANGUP, code=9001, state=1910
184424,42 1 LsXfer_8_WaitEndCall_RequestXferSide : 9001(EV_TIMEOUT_HANGUP),EV_TIMEOUT_HANGUP,0,0,0,,, (iModuleIdx=1)
184424,44 1 path {ev_timeout_hangup} not found
184424,45 1 rv add [Hangup Time]{24/03/2006 18:44:24}
184424,47 1 state Hanging up call... [Default Handler 60: 9001]
184424,50 1 rvns add [TsRoutedTo]{}
184424,52 2 rvns add [TsRoutedTo]{}
184424,53 1 TsReset dxxxB1C1</>dxxxB1C2 MATCH_ call
184424,69 1 TsReset dxxxB1C1</>dxxxB1C2 MATCH_ => []
184424,70 2 rv add [Hangup Time]{24/03/2006 18:44:24}
184424,72 2 state Hanging up call... [2nd leg (Hangup Call)]
184424,73 2 HangupCall_Common hCall=0
184424,77 2 rec RecSoundStop ok
184424,78 2 play PlaySoundStop ok
184424,80 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
184424,81 2 HangupCall : lCallHandle& = 0 - lets close and open line
184424,83 2 state Waiting for a call...
184424,86 2 fnHangupCall end
184424,89 1 HangupCall_Common hCall=1
184424,91 1 rec RecSoundStop ok
184424,92 1 play PlaySoundStop ok
184424,94 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
184424,95 1 fnHangupCall end
184424,97 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
184424,98 2 event ScriptEventCode TDX_SETHOOK, code=135, state=900
184425,02 2 LsAwaitingCalls EV_UNKNOWN_135
184425,03 2 event callstate IDLE 2 1,0,0
184425,05 2 WorkingMode@Idle=
184425,06 2 timer clear
184425,08 2 LineState(iLineId).iVgsIdx = 0
184425,09 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
184425,13 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
184425,14 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
184425,16 1 LsAwaitingCalls EV_UNKNOWN_135
184425,17 1 event callstate IDLE 1 1,0,0
184425,19 1 WorkingMode@Idle=
184425,20 1 timer clear
184425,22 1 rec RecSoundStop ok
184425,30 1 play PlaySoundStop ok
184425,31 1 rv add [CallEndTime]{24/03/2006 18:44:25}
184425,44 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
184426,45 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
184426,47 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
184426,48 1 init atidle reinit : start
184426,50 1 init atidle reinit iConferenceOtherLegLid=-1
184426,52 1 init atidle reinit : reset all LineState variables
184426,53 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
184426,56 1 state Waiting for a call...
184426,58 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
184426,59 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
184426,61 2 init atidle reinit : start
184426,63 2 init atidle reinit iConferenceOtherLegLid=-1
184426,64 2 init atidle reinit : reset all LineState variables
184426,67 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
184426,69 2 state Waiting for a call...
184427,03 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
184427,05 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
184427,06 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
184427,08 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Caller ID on analog lines arrives between 1st and 2nd 'ring' - so the number of rings must be set to 2 or higher so that caller ID can be received before answering.
