Guest Guest_badi Report post Posted 03/26/2006 12:30 PM hi all I need to ask : I had buy new PC with AMD prossissor (3000) mhz ....but I am not sure if dialogic cards work with AMD prossisors or not ..... pls can u help me about that ? what the difference between (30 ch ISDN) & (E1 with 30 voice channels) ? thanks with best regards Share this post Link to post
SupportTeam Report post Posted 03/26/2006 04:32 PM Intel recommends running the Intel/Dialogic cards on Intel CPU based systems... You can try with AMD, but most systems out there that use Intel/Dialogic cards use Intel CPUs as well... what the difference between (30 ch ISDN) & (E1 with 30 voice channels) ? Sounds like the same thing to me... Share this post Link to post
Guest Guest_badi Report post Posted 03/27/2006 01:05 PM thanx 4 reply, but I wanna know if I buy dialogic card support 30 ch ISDN & I connect E1 (2.048) mb/s with this card , is this card will work correctly with E1s ? best regards Share this post Link to post
SupportTeam Report post Posted 03/27/2006 08:30 PM Yes, an E1 card is a 30 channel ISDN card. Share this post Link to post
