plaqnix Report post Posted 03/28/2006 01:46 AM Hi, I have a problem with changing the script assigned to the phone line. It keeps defaulting to the Credit Card payment example. The vg.ini indicates in [CTMedia] that the script file I want is the default. So, how do you set the script to associate with the particular phone line? A. Campbell Share this post Link to post
SupportTeam Report post Posted 03/28/2006 02:18 AM Which version of VoiceGuide are you using? Share this post Link to post
plaqnix Report post Posted 03/28/2006 02:33 AM Hi VG 6.0.2322 Professional Share this post Link to post
SupportTeam Report post Posted 03/28/2006 02:43 AM In VoiceGuide for Dialogic the default scripts for each line are set in Config.xml file (see Vg's \data\ subdirectory). You need to edit Config.xml to make it match the Dialogic card you're using as well. The default Config.xml comes configured for 4 line analog card - but there are other sample Config.xml files provided in the VG for Dialogic download. Share this post Link to post
plaqnix Report post Posted 03/28/2006 03:38 AM That's pretty much fixed it. Thanks. Alistair C. Share this post Link to post
