Guest Tony Report post Posted 07/07/2003 09:57 PM Hi, After installing VoiceGuide 4.9.0,, when attempting to lauch VoiceGuide, an error appears: System Error &H8007007E (-2147024770). All other components work, such as Config Wizard, Voicemail Manager etc. Just the VoiceGuide application doesn't work. Any ideas? Tony. Share this post Link to post
SupportTeam Report post Posted 07/08/2003 12:33 AM Haven't seen this problem before... Which version of Windows are you using? Does the Script Designer start OK? Is the Config Wizard correctly displaying the voice modems / Dialogic cards and have you selected a modem/card and a script to use? Is there any other information in the error window? Share this post Link to post
Guest Danielle Report post Posted 10/20/2003 08:41 PM Hi, I have this problem with an application I developped. After reading a lot of news groups that had this problem, I can giva you more details on it, if you don't already know it. This problem occurs on Windows XP home/pro edition. It's a problem with some OCX and DLLs of Windows. Thousands of people have this problem (with a variety of different programs). Many solutions have been proposed but none work. Every case is sligthly different but mainly, it's a problem that occurs with a program that uses non-standard controls, like a tabstrip, msflexgrid,... Share this post Link to post
SupportTeam Report post Posted 10/21/2003 12:58 AM If anybody comes across their installation of VG having these problems I'd recommend just re-installing the latest Service Pack for their version of Windows - hopefully that will resolve any DLL/OCX incompatibility issues which seem to be causing such problems.. Share this post Link to post
Guest UKIAMDAUKUK Report post Posted 11/30/2003 09:18 AM http://www.superlogix.net GO TO THIS SITE AND DOWNLOAD THEIR SOFTWARE. Run the registry cleaner Delete all Job done, give my site a hit for helping http://www.uksolid.com If you still stuck pm me on aim at ukiamdaukuk Dont say ahh tut i ran a registery cleaner it didnt work, im TELLING you for the love of god this actually works. Share this post Link to post
Guest Rudy Report post Posted 12/24/2003 06:56 AM I found this forum in google when i typed in the error, and i wanted to say thank ya very much Share this post Link to post
Guest Rudy Report post Posted 12/24/2003 06:57 AM Ah, and I gave your site a hit too =D Share this post Link to post
Guest jn Report post Posted 01/01/2004 07:59 PM the super utilities worked for me. scan reg for invalid entries remove invaled entries done deal thanks Share this post Link to post
Guest Guest_justin Report post Posted 01/14/2004 10:51 AM System Error &H8007007E (-2147024770). someone plz tell me how i can get rid of that. im running windows xp pro. i would really appreciate it.dizzyloc1980@yahoo.com Share this post Link to post
SupportTeam Report post Posted 01/14/2004 11:29 AM ... plz read the previous posts... Share this post Link to post
Guest UKIAMDAUKUK Report post Posted 01/29/2004 07:47 AM Im guessing the above works for everyone because this forum has gone quiet. If your from http://www.superlogix.net i do have pay pal lol. Share this post Link to post
Guest kriso33 Report post Posted 02/06/2004 08:56 PM tried to run super utils. GOR ERROR MESS got 'access violition at 0x77FA49C5 (TRIED TO WRITE TO 0X02610FAC), PROG TERMINATED. ANYONE GOT ANY IDEAS?? CHEERS PHILIP Share this post Link to post
Guest ukiamdaukuk Report post Posted 02/07/2004 04:26 AM So you are getting a error on a prog that was suggested to you to fix another error ? I say forget it. Share this post Link to post
Guest PhREaK Report post Posted 02/08/2004 08:51 AM aight a lot of peeps are complaining of a system error: system error &h8007007e )-2147024770) and cant run certain apps well here is the fix for that just install these files and then register them and reboot and you should be set COMCTL32.OCX Comdlg32.ocx mscomct2.ocx MSCOMCTL.OCX msinet.ocx Mswinsck.ocx MSSTDFMT.DLL MSVBVM60.DLL TABCTL32.OCX vbskpro.ocx unzip the file and put it in your windows\system directory (( windows system directory... C:\WINDOWS\system )) (( my comptuer, local disk © then WINDOWS then system folder )) you need to register the newly installed DLL the best way is to run regsvr32.exe like this: Go to Start (left bottem) and run: "regsvr32.exe C:\WINDOWS\SYSTEM\xxxxxx.DLL" or "regsvr32.exe C:\WINDOWS\SYSTEM\xxxxxx.OCX" Using the first file as an example: Start run regsvr32.exe C:\WINDOWS\SYSTEM\COMCTL32.OCX Share this post Link to post
Guest UKIAMDAUKUK Report post Posted 02/10/2004 11:06 PM Why do all that when the error is caused by having 1 or more of them files registered. The problem is caused by having the same file twice. So to fix the problem the super logix deletes the invalid registry key. I THINK Share this post Link to post
Guest Guest Report post Posted 02/11/2004 02:10 AM Thanks UK.....did the job for me. Share this post Link to post
Guest dude Report post Posted 02/11/2004 08:04 PM hey phreak those things that you wrote, do they work for windows 95,98 or xp, cuz i got an xp and i get the same message when i open an application, its wierd, so i was wondering if you can message me back and tell me what i should do. and another thing, when i downloaded the regsvr32.exe, it showed me a message that says "no dll files specified" and some more things, and it won't open, so i need help on that, thanks alot, write back! pls Share this post Link to post
Guest jhon Report post Posted 03/02/2004 04:10 AM hi Uk......, where i have to go to delete the file ?? thanks ! Share this post Link to post
Guest UKIAMDAUKUK Report post Posted 03/04/2004 12:54 AM After you have ran the registry cleaner delete all the invalid entrys. For information or help on how to this please consult the super logix web site. Share this post Link to post
Guest UKIAMDAUKUK Report post Posted 03/04/2004 12:56 AM After you have ran the registry cleaner delete all the invalid entrys. For information or help on how to :-( do :-) this please consult the super logix web site. Share this post Link to post
Guest INTEL Report post Posted 06/05/2005 09:46 PM Hi all i'd jus like to say this was a great help when i was confronted with the system error &h8007007e, it wound me up trying to figure the problem but exactly how matey boy put it in previous forum, (which is now closed) the solution fixed machine error in less then two mins, good instruction good results i can now run a program i built, with out stressing out thinking my programming was out! ;P Share this post Link to post
