Guest Guest Report post Posted 03/29/2006 11:41 PM when i try to make outbound calls, all calls are being queued i have checked the dialing times. should i be checking anything else? Share this post Link to post
Guest Guest Report post Posted 03/29/2006 11:49 PM 155137.48 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] 155137.52 0 ERROR 6.0.3055 dial DbFindDueCall [Too few parameters. Expected 1.] 155137.52 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] 155137.55 0 ERROR 6.0.3055 dial DbFindDueCall [Too few parameters. Expected 1.] 155137.55 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] this is what the event trace log shows me... Share this post Link to post
SupportTeam Report post Posted 03/29/2006 11:51 PM Stop VG. Delete OutDialQue.mdb from VG's \data\ subdirectory. Restart VG. Reload the calls. Share this post Link to post
Guest Guest Report post Posted 03/29/2006 11:52 PM actually the event race outputs 155137.48 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] 155137.52 0 ERROR 6.0.3055 dial DbFindDueCall [Too few parameters. Expected 1.] 155137.52 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] 155137.55 0 ERROR 6.0.3055 dial DbFindDueCall [Too few parameters. Expected 1.] 155137.55 0 ERROR 6.0.3055 dial DbFindDueCall [Object variable or With block variable not set] without me trying to make the outbound call. Share this post Link to post
SupportTeam Report post Posted 03/29/2006 11:54 PM Stop VG. Delete OutDialQue.mdb from VG's \data\ subdirectory. Restart VG. Reload the calls. Share this post Link to post
