Problem After Playing A Sound File
Hello Support team,
I have a problem in a Play module (Play Module 1). I have only two paths for this module :
on {*} goto [Play Module 2]
on {timeout 0} goto [Play Module 2]
No repeat if no key pressed
After finishing playing my sound file, the systems waits 30 seconds before going to Play Module 2, pressing * or not. It's a big problem for me because users pay for each second of the call, and i can't make them wait so long time.
The event log trace is :
<Playing Play Module 1>
131436,54 0 dtmf * (66390,42,2)
131436,54 0 ScriptEventCode 42 iLineState=1100
131436,54 0 LsPlayMsg *
<Press *, the system waits about 30 seconds before playing Play Module 2. Starting playing Play Module 2 the trace continues with :>
131508,10 0 PlaySoundStop err=0
131508,10 0 rv lg add [Play Module 1]{*}
131508,15 0 timer clear
131508,16 0 state [Play Module 2] Playing
131508,16 0 state [Play Module 2] Playing (C:\....\sons\sound1.wav)
131508,16 0 play set playid=80731
131508,28 0 PlaySoundStart ok [C:\....\sons\sound1.wav]
131508,28 0 timer clear
131508,28 0 RunModule PLAY end
131512,61 0 dtmf 6 (66390,54,2)
131512,62 0 ScriptEventCode 54 iLineState=1100
131512,62 0 LsPlayMsg 6
131512,62 0 path {6} not found
131518,63 0 play end current play (playid=80731)
131518,63 0 ScriptEventCode 8001 iLineState=1100
131518,64 0 LsPlayMsg EV_PLAY_FINISHED
131518,64 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
131518,64 0 timer set 5 EV_TIMEOUT_REPLAYMSG
131519,05 0 dtmf 1 (66390,49,2)
131519,05 0 ScriptEventCode 49 iLineState=1101
131519,06 0 LsPlayMsgFinished 1
131519,06 0 rv lg add [Play Module 1]{1}
I use a voice modem.
Can you help me please ?
Last line is :
131519,06 0 rv lg add [Play Module 2]{1}
instead of
Please post the full 'vgm' and 'tw' traces capturing one entire call which demonstrates the problem.
(set logging to 10, then restart VG, make the call and post traces from VG's \data\ subdirectory).
Trace shows that the delay is due to the Modem's wave drivers waiting a long time before returning from waveOutReset and waveOutClose function calls...
131436.536 wavec waveOutReset(0x1c53c0) call, caller: PlaySoundStop
131458.087 wavec waveOutReset(0x1c53c0) => 0 (MMSYSERR_OK), caller: PlaySoundStop
131458.087 wavec waveOutClose(0x1c53c0) call, caller: PlaySoundStop
131508.101 wavec waveOutClose(0x1c53c0) => 0 (MMSYSERR_OK), caller: PlaySoundStop
You should try using another modem, or better yet just get a Dialogic card...
