Voicemail - Retrieving Messages
Within vg.ini I have set MessagePlaybackOrder=OldFirst. It still plays the newest messages first. Is there another setting. When the user listens to their messages they want to hear the oldest message first.
You will need to make changes in voicemail scripts (see VG's \system\vm\ subdirectory) if you would like to alter the way that the voicemail system works.
The setting you mention was used before the scripts based voicemail system was released. It is not currently used and should have been removed from VG.INI altogether.
