Connecting To Filemaker Pro 5.0 Database (odbc)
Anthony wrote:
I am looking for is the connect string between filemaker pro 5.0 ODBC compliant database and the Access query in the voice guide script editor. (Please see attachment).
When a tried to select a database from a drop down menu in the database query, I got just options for MS access and MS excel.
What I am trying to do is a solution similar to the one you have in the demo version called "CUSTOMER INQUIRY". But instead MS access or excel I want to use filemaker pro 5.0 database. (ODBC).
I followed your instructions and the application instructions to set up the ODBC in windows xp. But still I cannot find the right connect string between both applications.
Filemaker_SQL.zip
Instructions on what ODBC connect string the database's ODBC driver expects are usually supplied in that ODBC driver's documentation.
Read the sections of VG Help file which cover the installation of ODBC data sources, and this site may also be helpful:
http://www.connectionstrings.com/
