Channelized T1 Vs Isdn T1 Pri Line
We have a successful implementation of voiceguide using a T1 PRI line (ISDN).
However, we would like to purchase another license of voiceguide to run on a Channelized T1 with a dialogic D241 JCT board. Does voiceguide support channelized T1? The reason for doing this is that the Channelized T1 is a VOIP solution which enables us to pay a flat rate for LD calls.
OK, Channelized T1 - "CT1" is just another term for "Robbed Bit" lines...
Please confirm this with Telco to make sure that's what they mean...
Robbed Bit signaling is fine. Dialogic cards can work with Robbed Bit.
ISDN is preferred to Robbed Bit though as it provides more call information and is easier to setup...
