Call Transfer Path
HellO!
I have installed a new dialogic card D/4PCIUF with voiceguide for DG v6.0.3095 and I have two things that don´t work as I spected:
1. In the call transfer module I would like to use the AM path when an answering machine receives the call but it doesn´t work. It never goes to the module specified in the {AM} path.
2. And the second issue is that the "Event Trace Log" doesn´t show any log at all.
Thank you!
Jose
You can ignore the second point in the last question.
According to the tutorial in the transfer call module it is possible to use the {AM} path when using a dialogic card, should I make any configuration somewhere to make this work?
Thank you!
Jose
This path will only work for monitored hookflash transfers and monitored 3-way conference calls...
Note that no AM/Human detection is not 100% reliable... Dialogic does it much better then anybody els, but it's still not 100%.
