Script After Hangup Not Running!
Hi... I can't get any scripts to run after hangup. I went into the script settings under the Edit menu and selected the script I want to run after the call but it does not seam to run.
Please help!
Thanks!
That fixed the problem but now I have another problem.
I set the script to send a phone message and it isn't dialing out.
Here is the trace log for this example script I can't get to dial out using that module.
55905 0 tapie callstate OFFERING 66459 0 4
55905 0 tapie ring 1
58789 0 tapie ring 2
58789 0 Answer the call
58799 0 lineAnswer(66459) => 66135
58799 0 tapie callstate ACCEPTED 66459 0 0
60061 0 tapi Reply 66135 0
60071 0 tapie callstate CONNECTED 66459,0,0
60071 0 WorkingModeTAPI=
60071 0 WorkingModeScript=
60071 0 Inband detection not enabled
60071 0 StartLoadedVgs start
60071 0 [Phone Message 1] Make Outbound Call
60071 0 HangupCall called from [Run module 3018]
60081 0 Hanging up call...
60081 0 PlaySoundStop ok
60081 0 fnHangupCall end
60261 0 tapie callstate DISCONNECTED 66459,1,0
60271 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
60271 0 PlaySoundStop ok
60271 0 HangupCall called from []
60271 0 Hanging up call...
60281 0 fnHangupCall end
60281 0 tapie callstate IDLE 66459 0 0
60281 0 WorkingMode@Idle=
60291 0 set EV_TIMEOUT_TIMETOREINITLINE 2
60291 0 tapi Reply 66493 0
60301 0 tapi Reply 66442 0
61203 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
61203 0 ReinitTelephony due to IDLE start
61203 0 tapic lineDeallocateCall(MainCall:66459) 0
61824 0 lineOpen(0) => 0
61824 0 Waiting for a call...
61834 0 lineOpen(0)LineHandle=66476
61834 0 Loading from C:\Program Files\ivg\data\DialListNew.txt
61844 0 Loaded 1 entries.
Looks like the Make Outbound Call module completed it task (queued an outbound call to be made by the VoiceGudie Dialer), and then the script hangs up as there was no Success path defined for this module.
At the bottom of trace we can see that the IVG Dialer loaded the details of the new call to be made:
The Dialer will now make the call when a line becomes free.
Are you running an evaluation version or a registered version of VoiceGuide? If a registered version then have you purchased the Dialer add-on option?
Hi, I'm running the evaluation version. I did notice that it added the entry in to the dialer list but it does't dial out ever since I applied that patch.
Thanks.
I uninstalled IVG and reinstalled the version I downloaded and now the dialer works. So now I'm sure the problem is with the patch I applied. Are you guys working on a new one?
Thanks!
Hi, It's me again.
Ok, to summerize: Evaluation Version 4.9.0 Dialer works but afterhangup script does not. Version 4.9.1 (patch) Dialer doesn't work and afterhangup script does work.
I also noticed that in version 4.9.0, the message to phone (dialer module) does not exculate to the alternitive numbers. Here is a log of it if that helps. I noticed that after the first attempt with 0 retries it just removed the entry in the database. I also noticed that there is no data in the EscalationCalls field.
59870 0 tapie callstate OFFERING 65785 0 4
59870 0 tapie ring 1
62754 0 tapie ring 2
62754 0 Answer the call
62754 0 lineAnswer(65785) => 65563
62754 0 tapie callstate ACCEPTED 65785 0 0
64036 0 tapi Reply 65563 0
64046 0 tapie callstate CONNECTED 65785,0,0
64046 0 WorkingModeTAPI=
64046 0 WorkingModeScript=
64046 0 Inband detection not enabled
64046 0 [Run VB Script 1] Running VB Script...
64136 0 VBScript Run waiting...
65037 0 Found result file: VGRUNRESULT_0.TXT
65037 0 Run Results >>>[CallDate]{7/14/2003}[CallTime]{5:16:21 PM}[CallDay]{Mon}<<<
65047 0 [QueryTech] DB Query
65047 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
65057 0 RVreplace start: [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #$RV[CallDate]# And EndDate >= #$RV[CallDate]# And StartTime <= #$RV[CallTime]# And EndTime >= #$RV[CallTime]# And Days Like '*$RV[CallDay]*']
65057 0 RVreplace end: [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #7/14/2003# And EndDate >= #7/14/2003# And StartTime <= #5:16:21 PM# And EndTime >= #5:16:21 PM# And Days Like '*Mon*']
65057 0 About to execute Retrieve Operation [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #7/14/2003# And EndDate >= #7/14/2003# And StartTime <= #5:16:21 PM# And EndTime >= #5:16:21 PM# And Days Like '*Mon*']
65067 0 [QueryTech] row count=1
65077 0 [Phone Message 1] Make Outbound Call
65087 0 HangupCall called from [Run module 3018]
65087 0 Hanging up call...
65087 0 PlaySoundStop ok
65097 0 fnHangupCall end
65278 0 tapie callstate DISCONNECTED 65785,1,0
65288 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
65288 0 PlaySoundStop ok
65288 0 HangupCall called from []
65288 0 Hanging up call...
65298 0 PlaySoundStop ok
65298 0 fnHangupCall end
65298 0 tapie callstate IDLE 65785 0 0
65298 0 WorkingMode@Idle=
65318 0 set EV_TIMEOUT_TIMETOREINITLINE 2
65328 0 tapi Reply 66384 0
65328 0 tapi Reply 66469 0
66229 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
66229 0 ReinitTelephony due to IDLE start
66229 0 tapic lineDeallocateCall(MainCall:65785) 0
66860 0 lineOpen(0) => 0
66870 0 Waiting for a call...
66870 0 lineOpen(0)LineHandle=65717
66880 0 Loading from C:\Program Files\ivg\data\DialListNew.txt
66890 0 Loaded 1 entries.
66900 0 Ready To DialOut : 1 (out of 1)
68913 0 Ready To DialOut : 1 (out of 1)
70926 0 Ready To DialOut : 1 (out of 1)
72949 0 Ready To DialOut : 1 (out of 1)
72949 0 Dialing: 126
72959 0 MakeCall => 65920
72959 0 TapiCbTrigSet 65920 7002
72959 0 tapi Reply 65920 0
72959 0 TapiCbTrigClear
73069 0 tapie callstate DIALING 66041 0 0
73079 0 tapie callstate PROCEEDING 66041 0 0
76634 0 tapie callstate CONNECTED 66041,0,0
76634 0 WorkingModeTAPI=
76634 0 WorkingModeScript=
76634 0 Dialing: Playing introduction message
76694 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\AcceptAutoCall.wav]
76974 0 Erasing Script Id 1
83384 0 Play End line[0] (id=976654)
83384 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
83424 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\AcceptAutoCall.wav]
90113 0 Play End line[0] (id=983384)
90113 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
90163 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\AcceptAutoCall.wav]
96853 0 Play End line[0] (id=990123)
96853 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
96893 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\AcceptAutoCall.wav]
03583 0 Play End line[0] (id=996853)
03583 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
03593 0 DELETE FROM CallQue WHERE ID=24;
03593 0 HangupCall called from [play accept auto 2]
03603 0 Hanging up call...
03603 0 PlaySoundStop ok
03723 0 Waiting for a call...
03723 0 fnHangupCall end
03783 0 tapie callstate DISCONNECTED 66041,1,0
03793 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
03793 0 PlaySoundStop ok
03793 0 HangupCall called from []
03793 0 Hanging up call...
03803 0 PlaySoundStop ok
03803 0 Waiting for a call...
03803 0 fnHangupCall end
03803 0 tapie callstate IDLE 66041 0 0
03813 0 WorkingMode@Idle=
03813 0 LineState(iLineId).iVgsIdx = 0
03813 0 set EV_TIMEOUT_TIMETOREINITLINE 1
03823 0 set EV_TIMEOUT_TIMETOREINITLINE 2
03823 0 tapi Reply 66401 0
03833 0 tapi Reply 65768 0
04734 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
04734 0 ReinitTelephony due to IDLE start
04734 0 tapic lineDeallocateCall(MainCall:66041) 0
05375 0 lineOpen(0) => 0
05375 0 Waiting for a call...
05375 0 lineOpen(0)LineHandle=66315
05405 0 Erasing Script Id 2
Can you answer these questions please! I would greatly appreciate it! I need a stable version that will address these issues. Please see my other posts.
Thanks.
