Vb Error With Voice Mail
Whenever a new voicemail message is recorded by a caller the following Winsdows Script host error occurs.
The event process is outbound call made to person,
person elects to speak to an operator (announce tranfer)
After a time period we record a message so they dont have to hold too long.
Voice mail box message plays
When you go to record a message the below error flashes up
Script: C:\Program Files\VoiceGuide\data\vbs_1_3.vbs
Line 19
Char 6
Error: Expected ' Then'
Code: 800A03F9
Source: Microsoft VB SCript Compilation Error
The trace from the call is attached
Error_voicemail.doc
Did you modify the voicemail script that are supplied with VoiceGuide?
Trace shows that the error is happening in module [VmLmRecInit] (Run VBScript module) and it appears to be in a malformed "if...then" statement... (on line 19).
In current voicemail scripts line 19 in module [VmLmRecInit] is blank..., with the next line being:
if "$RV_CIDNUMBER" = "" then
(which should not cause any problems)
If you still cannot see what the problem is the please post file C:\Program Files\VoiceGuide\system\vm\VmLm.vgs from your system and we can see what it is on line 19 in module [VmLmRecInit] that may be causing the problem.
174550.13   1 state [VmLmWelc] Playing (C:\Program Files\VoiceGuide\data\VmWelc\0002.wav)
174609.38   1 state [VmLmRecInit] Running VB Script...
