Disabling Inband Signaling Wait Time
I've been searching alot and haven't figured this one out.
I want VG (5.2.3) to answer call as soon as it rings in the line!
I know my d4/pci card is waiting about 2 rings before transferring to VG (acquiring callID and stuff) but is there a way to skip callerid waiting and just answer as quickly as possible?
thank you.
Anthony.
You will need to use "VG for Dialogic", or if you want to continue using v5.x of VG then you'll need to disable CallerID waiting in the Dialogic's TAPI drivers and set the "Report Incomig Call" setting (in the Dialogic's TAPI drivers) to 0.
thank you it did fix that problem!
now I have new issues and after an 1hour looking can't seem to fix it but ill do a new post for that!
