Vg Just Stopped Working
About a week ago VG just stopped working for reason whatsoever. We run the machine back a couple of weeks and its still not happy. Its odd cause its been running fine for a year or so and nothing has been done to that machine at all.
One interesting fact is that the machine locks solid when it answers the call, and unfreezes after the call (where nothing happens) is hung up.
The log is below.
Any help would be greatly appreciated.
Regards,
Justin
155141.67 0 callstate OFFERING 66082 0 4
155141.67 0 ring 1
155141.86 0 dial start any summary:|0:hc>0|
155144.65 0 ring 2
155144.65 0 rv clear
155144.65 0 Answer the call at 04/05/2006 15:51:44
155144.66 0 lineAnswer(66082) => 66065
155144.66 0 callstate ACCEPTED 66082 0 0
155204.74 0 tapi Reply (LineEvReply) err 66065 LINEERR_OPERATIONFAILED [80000048]
155204.74 0 callstate DISCONNECTED 66082 16384 0
155204.74 0 ScriptEventCode 9250 iLineState=900
155204.74 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
155204.75 0 rv add [Hangup Time]{04/05/2006 15:52:04}
155204.75 0 Hanging up call...
155204.75 0 RecSoundStop ok
155204.76 0 PlaySoundStop err=0
155204.76 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
155204.76 0 Waiting for a call...
155204.77 0 fnHangupCall end
155204.77 0 callstate IDLE 66082 0 0
155204.78 0 WorkingMode@Idle=
155204.78 0 timer clear
155204.79 0 LineState(iLineId).iVgsIdx = 0
155204.79 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
155204.82 0 tapi Reply (LineEvReply) ok 66048 0
155205.71 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
155205.71 0 ScriptEventCode 9008 iLineState=900
155205.72 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
155205.72 0 ReinitTelephony due to IDLE
155205.75 0 tapic lineDeallocateCall(MainCall:66082) 0
155206.77 0 lineOpen(0)=>
155206.77 0 Waiting for a call...
155206.77 0 LineHandle=66047
155206.79 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
155206.80 0 dial start any summary:|0:rdy=0|
155209.87 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
155209.88 0 ScriptEventCode 9013 iLineState=900
155210.83 0 dial start any summary:|0:idx=0|
Trace shows the TAPI driver are returning an error when "Line Answer" is command is issued to them:
I'd try re-installing the TAPI drivers...
