Guest Tom Storey Report post Posted 05/05/2006 08:16 PM I made a test script using Play_Start inside Run VBScript. set vg = CreateObject("VoiceGuide.CommandLink") vg.Play_Start $RV_LINEID, "Sound Files\Student ID Not Found.wav" Set vg = Nothing The sound file plays OK, but the program never move on. The debug file is below: 160052.74 6 devstate NUMCALLS 0 0 160052.74 6 tapi callstate OFFERING 65838 0 4 160052.74 6 rv clear 160052.74 6 answer the call at 2006-05-05 16:00:52 160052.76 6 lineAnswer(65838) => 66350 160052.76 6 ev Lev_CallerID [,,0000] 160052.76 6 rv lg add [DNIS]{0000} 160052.76 6 callinfo CALLEDID 160052.76 6 callinfo ORIGIN 160052.76 6 ring 0 160053.29 6 tapi callstate CONNECTED 65838 1 0 160053.29 6 callstate CONNECTED 65838,1,0 160053.29 6 WorkingModeTAPI@Connected= 160053.30 6 WorkingModeScript@Connected= 160053.34 6 Inband detection not enabled 160053.34 6 startLoadedVgs at 2006-05-05 16:00:53, script interpretor VgMulti v5.2.5049 3 160053.34 6 rv ns add [scriptsPath]{C:\Phone Registration 2007-2008\Start_Stop Here\} 160053.34 6 rv ns add [scriptPath]{C:\Phone Registration 2007-2008\Start_Stop Here} 160053.34 6 rv lg add [$RV_STARTTIME]{2006-05-05 16:00:53} 160053.34 6 rv lg add [$RV_DEVICEID]{6} 160053.34 6 rv lg add [$RV_CIDNAME]{} 160053.35 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\} 160053.35 6 rv lg add [$RV_CIDNUMBER]{} 160053.35 6 rv lg add [$RV_DNIS]{0000} 160053.35 6 rv lg add [DNIS]{0000} 160053.35 6 tapi Reply (LineEvReply) ok 66350 0 LineCallState=CONNECTED 160053.35 6 callinfo MONITORMODES 160053.35 6 timer clear 160053.37 6 state [Test VB Script] Running VB Script... 160053.37 6 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink") vg.Play_Start $RV_LINEID, "Sound Files\Student ID Not Found.wav" Set vg = Nothing ] 160053.37 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{0000}[scriptsPath]{C:\Phone Registration 2007-2008\Start_Stop Here\}[scriptPath]{C:\Phone Registration 2007-2008\Start_Stop Here}[$RV_STARTTIME]{2006-05-05 16:00:53}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{0000}[DNIS]{0000} 160053.37 6 rv replace end: [set vg = CreateObject("VoiceGuide.CommandLink") vg.Play_Start 6, "Sound Files\Student ID Not Found.wav" Set vg = Nothing ] 160053.37 6 eng run vbs [wscript "C:\Program Files\VoiceGuide\temp\vbs_6_1_0505160053.vbs" //I] copy of script in: vbs_6_1_0505160053.vbs 160053.40 6 Run Script waiting. iRunWait=2 (shellid=1560, process=1456) 160053.40 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 160053.43 6 cl Play_Start Sound Files\Student ID Not Found.wav 160053.43 6 play set playid=595875 160053.46 6 PlaySoundStart ok [sound Files\Student ID Not Found.wav] 160053.46 6 timer clear 160053.46 6 callinfo MONITORMODES 160053.62 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0| **** The file stops here when the sound file is playing. 160115.68 6 play end current play (playid=595875) 160115.68 6 ScriptEventCode 8001 iLineState=1501 160115.68 6 LsRunWaitTillFinished EV_PLAY_FINISHED *** After the sound file stops the above lines come on and the script just set here. If I let it just set there, after a while this will be added to the debug file: 160134.27 0 sys cleanup Start 160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505143715.vbs 160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144302.vbs 160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144406.vbs 160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144428.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144555.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144708.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144757.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145000.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145240.vbs 160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145333.vbs 160134.30 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145409.vbs 160134.30 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145445.vbs 160134.35 0 sys cleanup End *** Then it just set here until I hang up. 160234.41 6 tapi callstate DISCONNECTED 65838 0 0 160234.41 6 ScriptEventCode 9250 iLineState=1501 160234.41 6 LsRunWaitTillFinished EV_REMOTEPARTY_DISCONNECT 160234.41 6 rv lg add [Hangup Time]{2006-05-05 16:02:34} 160234.41 6 state Hanging up call... 160234.41 6 RecSoundStop ok 160234.41 6 PlaySoundStop err=0 160234.41 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 160234.41 6 fnHangupCall end 160234.46 6 devstate NUMCALLS 0 0 160234.46 6 tapi callstate IDLE 65838 0 0 160234.46 6 WorkingMode@Idle= 160234.46 6 timer clear 160234.46 6 WriteToLogFiles_CurrScriptOnly start 160234.46 WriteToLogFiles_DoWrite start (C:\Phone Registration 2007-2008\Start_Stop Here\TestSound) 160234.46 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 160234.46 6 tapi Reply (LineEvReply) ok 66231 0 LineCallState=IDLE 160235.51 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 160235.51 6 ScriptEventCode 9008 iLineState=900 160235.51 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 160235.51 6 ReinitTelephony due to IDLE 160235.51 6 tapic lineDeallocateCall(MainCall:65838) 0 160235.66 6 lineOpen(6)=> 160235.66 6 state Waiting for a call... 160235.66 6 LineHandle=66384 160235.66 6 ClearCallHandle called from ReinitAtIdle 160235.66 6 amchk set AMdet=False in Reinit@idle 160235.66 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 160236.10 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0| 160238.95 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 160238.95 6 ScriptEventCode 9013 iLineState=900 160239.13 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0| *** Why doesn't the script quit at the end of the sound file? Share this post Link to post
SupportTeam Report post Posted 05/08/2006 03:07 AM I see that you are using the 'TAPI' version of VG. Are you using a Dialogic card? If you are using a Dialogic card then you should really update to using "VoiceGuide for Dialogic" If you want to keep on using the TAPI version of VG then please try updating with attached .exe Also, you may want to use Run_ResultReturn COM function if you'd like for system to go to another module afterwards. eg: set vg = CreateObject("VoiceGuide.CommandLink") vg.Play_Start $RV_LINEID, "Sound Files\Student ID Not Found.wav" vg.Run_ResultReturn $RV_LINEID, "AfterPlayEnds" Set vg = Nothing will result in VG going to module [AfterPlayEnds] when the sound file Student ID Not Found.wav finishes playing. VgMulti_5.2.5051.zip Share this post Link to post
