Using Play_start
I made a test script using Play_Start inside Run VBScript.
vg.Play_Start $RV_LINEID, "Sound Files\Student ID Not Found.wav"
Set vg = Nothing
The sound file plays OK, but the program never move on.
The debug file is below:
160052.74 6 devstate NUMCALLS 0 0
160052.74 6 tapi callstate OFFERING 65838 0 4
160052.74 6 rv clear
160052.74 6 answer the call at 2006-05-05 16:00:52
160052.76 6 lineAnswer(65838) => 66350
160052.76 6 ev Lev_CallerID [,,0000]
160052.76 6 rv lg add [DNIS]{0000}
160052.76 6 callinfo CALLEDID
160052.76 6 callinfo ORIGIN
160052.76 6 ring 0
160053.29 6 tapi callstate CONNECTED 65838 1 0
160053.29 6 callstate CONNECTED 65838,1,0
160053.29 6 WorkingModeTAPI@Connected=
160053.30 6 WorkingModeScript@Connected=
160053.34 6 Inband detection not enabled
160053.34 6 startLoadedVgs at 2006-05-05 16:00:53, script interpretor VgMulti v5.2.5049 3
160053.34 6 rv ns add [scriptsPath]{C:\Phone Registration 2007-2008\Start_Stop Here\}
160053.34 6 rv ns add [scriptPath]{C:\Phone Registration 2007-2008\Start_Stop Here}
160053.34 6 rv lg add [$RV_STARTTIME]{2006-05-05 16:00:53}
160053.34 6 rv lg add [$RV_DEVICEID]{6}
160053.34 6 rv lg add [$RV_CIDNAME]{}
160053.35 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
160053.35 6 rv lg add [$RV_CIDNUMBER]{}
160053.35 6 rv lg add [$RV_DNIS]{0000}
160053.35 6 rv lg add [DNIS]{0000}
160053.35 6 tapi Reply (LineEvReply) ok 66350 0 LineCallState=CONNECTED
160053.35 6 callinfo MONITORMODES
160053.35 6 timer clear
160053.37 6 state [Test VB Script] Running VB Script...
160053.37 6 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
Set vg = Nothing
160053.37 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{0000}[scriptsPath]{C:\Phone Registration 2007-2008\Start_Stop Here\}[scriptPath]{C:\Phone Registration 2007-2008\Start_Stop Here}[$RV_STARTTIME]{2006-05-05 16:00:53}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{0000}[DNIS]{0000}
160053.37 6 rv replace end: [set vg = CreateObject("VoiceGuide.CommandLink")
vg.Play_Start 6, "Sound Files\Student ID Not Found.wav"
Set vg = Nothing
160053.37 6 eng run vbs [wscript "C:\Program Files\VoiceGuide\temp\vbs_6_1_0505160053.vbs" //I] copy of script in: vbs_6_1_0505160053.vbs
160053.40 6 Run Script waiting. iRunWait=2 (shellid=1560, process=1456)
160053.40 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
160053.43 6 cl Play_Start Sound Files\Student ID Not Found.wav
160053.43 6 play set playid=595875
160053.46 6 PlaySoundStart ok [sound Files\Student ID Not Found.wav]
160053.46 6 timer clear
160053.46 6 callinfo MONITORMODES
160053.62 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0|
**** The file stops here when the sound file is playing.
160115.68 6 play end current play (playid=595875)
160115.68 6 ScriptEventCode 8001 iLineState=1501
160115.68 6 LsRunWaitTillFinished EV_PLAY_FINISHED
*** After the sound file stops the above lines come on and the script just set here.
If I let it just set there, after a while this will be added to the debug file:
160134.27 0 sys cleanup Start
160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505143715.vbs
160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144302.vbs
160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144406.vbs
160134.27 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144428.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144555.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144708.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505144757.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145000.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145240.vbs
160134.29 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145333.vbs
160134.30 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145409.vbs
160134.30 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_6_1_0505145445.vbs
160134.35 0 sys cleanup End
*** Then it just set here until I hang up.
160234.41 6 tapi callstate DISCONNECTED 65838 0 0
160234.41 6 ScriptEventCode 9250 iLineState=1501
160234.41 6 LsRunWaitTillFinished EV_REMOTEPARTY_DISCONNECT
160234.41 6 rv lg add [Hangup Time]{2006-05-05 16:02:34}
160234.41 6 state Hanging up call...
160234.41 6 RecSoundStop ok
160234.41 6 PlaySoundStop err=0
160234.41 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
160234.41 6 fnHangupCall end
160234.46 6 devstate NUMCALLS 0 0
160234.46 6 tapi callstate IDLE 65838 0 0
160234.46 6 WorkingMode@Idle=
160234.46 6 timer clear
160234.46 6 WriteToLogFiles_CurrScriptOnly start
160234.46 WriteToLogFiles_DoWrite start (C:\Phone Registration 2007-2008\Start_Stop Here\TestSound)
160234.46 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
160234.46 6 tapi Reply (LineEvReply) ok 66231 0 LineCallState=IDLE
160235.51 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
160235.51 6 ScriptEventCode 9008 iLineState=900
160235.51 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
160235.51 6 ReinitTelephony due to IDLE
160235.51 6 tapic lineDeallocateCall(MainCall:65838) 0
160235.66 6 lineOpen(6)=>
160235.66 6 state Waiting for a call...
160235.66 6 LineHandle=66384
160235.66 6 ClearCallHandle called from ReinitAtIdle
160235.66 6 amchk set AMdet=False in Reinit@idle
160235.66 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
160236.10 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0|
160238.95 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
160238.95 6 ScriptEventCode 9013 iLineState=900
160239.13 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0|
*** Why doesn't the script quit at the end of the sound file?
I see that you are using the 'TAPI' version of VG.
Are you using a Dialogic card? If you are using a Dialogic card then you should really update to using "VoiceGuide for Dialogic"
If you want to keep on using the TAPI version of VG then please try updating with attached .exe
Also, you may want to use Run_ResultReturn COM function if you'd like for system to go to another module afterwards. eg:
vg.Run_ResultReturn  $RV_LINEID, "AfterPlayEnds"
Set vg = Nothing
will result in VG going to module [AfterPlayEnds] when the sound file Student ID Not Found.wav finishes playing.
VgMulti_5.2.5051.zip
