How Does $rv[voicemail Box Xxxx] Work?
Hi again everyone. I read in the help file that this result variable is available to use. So in my case, I would like the script to say the last filename in mail box 911. I entered $RV[Voicemail Box 911] and it does not work. I also tried in VBScript to save this to the results file and only the text appears, not the filename.
Any ideas?
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, along with your script, this will allow us to see what is going wrong.
