Script Can't Be Loaded When Using Chinese In Tts
When I test VG's TTS, I put some Chinese into the script's Play module TTS textbox. after saving the file, I can not reopen the vgs file to modify, and voiceguide can't use the script file. what's the problem?
Here is the script:
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Play 1
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[Play 1]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
Replay=2,5
strTtsText=我想试一试
Position=40,48
1.vgs
Attached script opened fine in both Script Designer v5.2.5001 and v6.0.2005
The characters we saw in the TTS text box were something like this:
ÎÒÏëÊÔÒ»ÊÔ
Maybe you should try to save the TTS text in a text file (.txt) and then just specify that .txt file as the sound file. VG at runtime will open the text file, read it in and pass it to the TTS engine.
