Script Doesn't Support Uni-code
I put some word in some other language, for example, Chinese, in Play module's TTS text box and Data Query module's SQL text box, and save the script file. then I can't open the file again to edit. VG can't load the file containing UNI-Code words.
Maybe you could assign a value to an RV and use the RV as part of the SQL query in the DB query module? (or just assign the entire SQL expression to an RV and just use the RV in DB Query module).
RVs could be assigned within a VBScript module - and you would need to write a VBScript to read in the data from a text file and assign the read in info to an RV.
