Demo Is Not Working
I'm trying to run your demo on a 1ghz P3, 512mb, Win2k, SP4, Zoom 56k DualModem. The log file for 2 calls follows. Both show the wav files not playing until I hit a digit followed by other failures. Other tries have produced erratic results, all similar, and none working. This is running your credit card payment script, unmodified.
Can you tell what's happening here?
Kevin
05963 0 tapie callstate OFFERING 66359 0 4
05973 0 tapie ring 1
11891 0 tapie ring 2
11901 0 Answer the call
11901 0 lineAnswer(66359) => 66325
11901 0 tapie callstate ACCEPTED 66359 0 0
13393 0 tapi Reply 66325 0
13404 0 tapie callstate CONNECTED 66359,0,0
13404 0 WorkingModeTAPI=
13404 0 WorkingModeScript=
13404 0 Inband detection not enabled
13404 0 [Get Client ID] Number Input
13414 0 [Get Client ID] Playing (PayGetId.wav)
13784 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Credit Card Payment\PayGetId.wav]
-------The wav file doesn't start playing until I enter a digit. Then it plays and cuts off before the end
22276 0 Play End line[0] (id=113414)
22276 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
24059 0 tapie monitordigits 49 2
24059 0 LsGetNbrsRxDigits [1]
24059 0 [Get Client ID] Number Input 1
24489 0 tapie monitordigits 50 2
24499 0 LsGetNbrsRxDigits [2]
24499 0 [Get Client ID] Number Input 12
24850 0 tapie monitordigits 51 2
24860 0 LsGetNbrsRxDigits [3]
24860 0 [Get Client ID] Number Input 123
25241 0 tapie monitordigits 52 2
25251 0 LsGetNbrsRxDigits [4]
25251 0 [Get Client ID] Number Input 1234
25621 0 tapie monitordigits 53 2
25621 0 LsGetNbrsRxDigits [5]
25621 0 [Get Client ID] Number Input 12345
26382 0 tapie monitordigits 35 2
26392 0 LsGetNbrsRxDigits [#]
26392 0 [Get Card Number] Number Input
26392 0 [Get Card Number] Playing (PayGetCc.wav)
26582 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Credit Card Payment\PayGetCc.wav]
31439 0 wb(12640200)
-------Again, doesn't start playing until I enter a digit, and cuts off early
41444 0 Play End line[0] (id=126402)
41454 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
41454 0 tapie monitordigits 48 2
41454 0 LsGetNbrsRxDigits [0]
41454 0 [Get Card Number] Number Input 0
44148 0 tapie monitordigits 57 2
44148 0 LsGetNbrsRxDigits [9]
44158 0 [Get Card Number] Number Input 09
44438 0 tapie monitordigits 56 2
44448 0 LsGetNbrsRxDigits [8]
44448 0 [Get Card Number] Number Input 098
44688 0 tapie monitordigits 55 2
44688 0 LsGetNbrsRxDigits [7]
44688 0 [Get Card Number] Number Input 0987
44959 0 tapie monitordigits 54 2
44969 0 LsGetNbrsRxDigits [6]
44969 0 [Get Card Number] Number Input 09876
45259 0 tapie monitordigits 53 2
45259 0 LsGetNbrsRxDigits [5]
45259 0 [Get Card Number] Number Input 098765
46942 0 tapie monitordigits 35 2
46952 0 LsGetNbrsRxDigits [#]
46952 0 [Get Expiry Date] Number Input
46952 0 [Get Expiry Date] Playing (PayGetExp.wav)
-----Doesn't play, and dies
56986 0 Play Start line[0] err=[0 wavec waveOutOpen(0x1c898c, 0x0, 0x1c8958, 0x1908bc, 0x1c8930, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] file[C:\Program Files\ivg\Scripts\Credit Card Payment\PayGetExp.wav]
67021 0 PlaySoundStart line[0] err=[0 wavec waveOutOpen(0x1c898c, 0x0, 0x1c8958, 0x1908bc, 0x1c8930, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] [C:\Program Files\ivg\system\voice\ErrorPlayingFile.wav]
67021 0 HangupCall called from [srlib 609]
67031 0 Hanging up call...
67031 0 PlaySoundStop ok
67031 0 fnHangupCall end
67041 0 tapie monitordigits 48 2
67041 0 LsAwaitingCalls [0]
68943 0 Hanging up call...(2)
68943 0 PlaySoundStop ok
68953 0 fnHangupCall end
68953 0 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
68953 0 tapi Reply 66188 0
88311 0 tapie callstate DISCONNECTED 66359,1,0
88311 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
88311 0 PlaySoundStop ok
88311 0 HangupCall called from []
88321 0 Hanging up call...
-----Doesn't hang up phone.
88321 0 PlaySoundStop ok
88321 0 fnHangupCall end
88331 0 tapie callstate IDLE 66359 0 0
88331 0 WorkingMode@Idle=
88341 0 set EV_TIMEOUT_TIMETOREINITLINE 2
88341 0 tapi Reply 66239 0
88341 0 tapi Reply 66530 0
89253 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
89253 0 ReinitTelephony due to IDLE start
89253 0 tapic lineDeallocateCall(MainCall:66359) 0
89263 0 tapie close 0
89263 0 Unavailable
89283 0 lineOpen(0) => 0
89283 0 Waiting for a call...
89283 0 lineOpen(0)LineHandle=66547
95311 0 tapie close 0
95311 0 Unavailable
Second call
50945 0 tapie callstate OFFERING 66120 0 4
50945 0 tapie ring 1
56874 0 tapie ring 2
56874 0 Answer the call
56884 0 lineAnswer(66120) => 66171
56884 0 tapie callstate ACCEPTED 66120 0 0
58356 0 tapi Reply 66171 0
58356 0 tapie callstate CONNECTED 66120,0,0
58356 0 WorkingModeTAPI=
58366 0 WorkingModeScript=
58366 0 Inband detection not enabled
58366 0 [Get Client ID] Number Input
58366 0 [Get Client ID] Playing (PayGetId.wav)
58746 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Credit Card Payment\PayGetId.wav]
67188 0 wb(35837600)
------Started playing, accepted digits
77193 0 Play End line[0] (id=358376)
77193 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
77193 0 tapie monitordigits 48 2
77193 0 LsGetNbrsRxDigits [0]
77203 0 [Get Client ID] Number Input 0
79506 0 tapie monitordigits 57 2
79506 0 LsGetNbrsRxDigits [9]
79506 0 [Get Client ID] Number Input 09
79877 0 tapie monitordigits 56 2
79877 0 LsGetNbrsRxDigits [8]
79887 0 [Get Client ID] Number Input 098
80708 0 tapie monitordigits 55 2
80708 0 LsGetNbrsRxDigits [7]
80708 0 [Get Client ID] Number Input 0987
84543 0 tapie monitordigits 35 2
84543 0 LsGetNbrsRxDigits [#]
84553 0 [Get Card Number] Number Input
84553 0 [Get Card Number] Playing (PayGetCc.wav)
-----Didn't play, didn't hang up, died
94578 0 Play Start line[0] err=[0 wavec waveOutOpen(0x1c8a9c, 0x0, 0x1c8a68, 0x13080a, 0x1c8a40, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] file[C:\Program Files\ivg\Scripts\Credit Card Payment\PayGetCc.wav]
04612 0 PlaySoundStart line[0] err=[0 wavec waveOutOpen(0x1c8a9c, 0x0, 0x1c8a68, 0x13080a, 0x1c8a40, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] [C:\Program Files\ivg\system\voice\ErrorPlayingFile.wav]
04612 0 HangupCall called from [srlib 609]
04612 0 Hanging up call...
04622 0 PlaySoundStop ok
04622 0 fnHangupCall end
04622 0 tapie monitordigits 48 2
04632 0 LsAwaitingCalls [0]
04632 0 tapie monitordigits 48 2
06535 0 Hanging up call...(2)
06535 0 PlaySoundStop ok
06545 0 fnHangupCall end
06545 0 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
06545 0 tapi Reply 65932 0
25893 0 tapie callstate DISCONNECTED 66120,1,0
25893 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
25893 0 PlaySoundStop ok
25903 0 HangupCall called from []
25903 0 Hanging up call...
25903 0 PlaySoundStop ok
25903 0 fnHangupCall end
25913 0 tapie callstate IDLE 66120 0 0
25913 0 WorkingMode@Idle=
25923 0 set EV_TIMEOUT_TIMETOREINITLINE 2
25923 0 tapi Reply 65796 0
25923 0 tapi Reply 66001 0
26874 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
26874 0 ReinitTelephony due to IDLE start
26884 0 tapic lineDeallocateCall(MainCall:66120) 0
26884 0 tapie close 0
26894 0 Unavailable
26904 0 lineOpen(0) => 0
26904 0 Waiting for a call...
26914 0 lineOpen(0)LineHandle=65881
32943 0 tapie close 0
32943 0 Unavailable
It does look like there is something very strange happening with that modem's wave drivers,
The trace is actually showing that the wave driver has confirmed that it has started playing the sound file immediately. The command to play the sound file is issued to the modem immediately after connect, and the modems wave driver did respond that it has started the play correctly 300ms later:
If re-installing the modem does not fix this problem then Id recommend just getting another modem...
