Transfer Problem
I'm exeriencing strange behaviour of VG for Dialogic with Dialogic 4 ports card. I'm trying to transfer a call to some local number, the transfer goes ok & I can hear answering machine speaking on another number, but once VG hangs up, I start hear intercept (ciren) tone instead of answering machine.
At the same time if I won't wait till VG hangs up and just press "hang up" in the window, everything works fine - VG will waiting for the call again & I will be listening to answering machine.
Does anybody have ideas what is the problem?
I forgot to say that the phone system I'm using is called Avaya Definity G3i
Maybe it can help you in understanding the problem.
Please post traces capturing the entire call if VG completes the transfer.
What are the "PBX Strings" set to?
There is log file if I use blind transfer
111240.578 001 ev TDX_CST (CST Event Received)
111240.578 001 ev TDX_CST DE_LCOF data=4074
111240.578 001 ocxev DoFireDialogic(dwIdx=17, 1, 134, [TDX_CST], 4074, 0, 0, [DE_LCOF], [], []) (dwIdx=17)
111240.578 001 ocxfn RingsBeforeAnswer(lLineId=1, lRings=0, lParam1=0, strParam2=)
111240.578 001 ocxev DoFireDialogic completed
111240.578 001 ev DE_LCOF does not cause DISCONNECTED event as Rule: SendDisconnectOnLoopCurrentDrop=0
111240.671 001 ev TDX_CST (CST Event Received)
111240.671 001 ev TDX_CST DE_LCON data=10
111240.671 001 ocxev DoFireDialogic(dwIdx=18, 1, 134, [TDX_CST], 10, 0, 0, [DE_LCON], [], []) (dwIdx=18)
111240.671 001 ocxev DoFireDialogic completed
111245.421 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,0,
111245.531 ------------------------------------------------------------------------------
111245.531 ktTelControl OCX v2.3.7, Apr 6 2006 18:11:09 [For Dialogic]
111245.531 Initialise at 0518 111245.531
111245.531 dlgc Dialogic boards present: dti:0, dxxx:1
111245.593 fn AppInit_Dialogic
111245.593 init test NETWORK devices (1st channel on each board)
111245.593 init test VOICE devices (1st device on each voice board)
111245.750 001 dlgc dx_open(dxxxB1) => 1
111245.750 init config board file [C:\Program Files\VoiceGuide\data\Config.xml]
111245.765 001 init config board file load start (len=5342)
111245.765 001 dlgc dx_setparm(1, DXBD_FLASHTM, &[50]) => 0,
111245.765 001 dlgc dx_setparm(1, DXBD_MINLCOFF, &[50]) => 0,
111245.765 001 dlgc dx_setparm(1, DXBD_MINOFFHKTM, &[250]) => 0,
111245.765 001 dlgc dx_setparm(1, DXBD_MINSLOFF, &[2]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_MINSLON, &[1]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_MINTIOFF, &[5]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_MINTION, &[5]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_OFFHDLY, &[50]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_PAUSETM, &[100]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_S_BNC, &[4]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_T_IDD, &[15]) => 0,
111245.781 001 dlgc dx_setparm(1, DXBD_TTDATA, &[10]) => 0,
111245.781 001 init config board file load end
111245.796 002 dlgc dx_open(dxxxB1C1) => 2
111245.796 dlgc dxxxB1C1 id=0x6021, family=2, devmode=0, network=3(Analog), bus=0, encode=1
111245.796 ft_play=0x57ff, ft_record=0x5fff, ft_tone=0x7, ft_e2p_brd_cfg=0x6, ft_fax=0x30
111245.796 002 dlgc dx_close(2) ok (channel dxxxB1C1)
111245.796 001 dlgc dx_close(1) ok (board dxxxB1)
111245.796 init enable event processing
111245.796 gc gc_start call
111245.812 eng CtEventPolling thread start
111247.265 000 ocxfn SetParam(0,VgIniFilename,c:\program files\voiceguide\VG.INI,0)
111247.265 SetParam VgIniFilename
111247.296 ocxfn GetLineCount() => 0
111247.562 ocxfn LineOpenDialogic(dxxx=dxxxB1C1, dti=dxxxB1C1, protocol=pdk_na_an_io, opt=, opt=0)
111247.562 init opening straight analog line
111247.562 001 dlgc dx_open(dxxxB1C1) => 1
111247.562 dlgc initial lines state is offhook. will return line to offhook on exit.
111247.562 001 DlgcVoice_SetConfig_AwaitCall start
111247.562 001 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C1|dxxxB1C1]
111247.562 001 init config line file not specified. default settings will remain.
111247.562 001 dx_sethook call (LineOpenDialogic)
111247.562 001 dx_sethook 1 DX_ONHOOK ok
111247.562 001 init LineOpenDialogic (analog) ok => [1]
111247.562 001 ocxfn SetParam(1,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
111247.562 SetParam ConfigLine_Filename begin
111247.562 001 tone section start A
111247.609 001 ev TDX_SETHOOK (SetHook Completed)
111247.609 001 dlgc tones_del(1) returned ok
111247.609 001 tone section start B
111247.609 001 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
111247.625 001 init config line file load start (len=11373)
111247.625 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
111247.625 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
111247.625 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
111247.625 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
111247.625 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
111247.625 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
111247.625 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
111247.625 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
111247.625 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
111247.625 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
111247.625 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
111247.625 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
111247.625 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
111247.625 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
111247.625 001 dlgc dx_setparm(1, DXCH_CALLID, &[1]) => 0, ok
111247.625 001 dlgc dx_setparm(1, DXCH_DTMFDEB, &[0]) => 0, ok
111247.625 001 dlgc dx_setparm(1, DXCH_DTMFTLK, &[5]) => 0, ok
111247.625 001 dlgc dx_setparm(1, DXCH_MINRWINK, &[10]) => 0, ok
111247.625 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
111247.625 001 dlgc dx_setparm(1, DXCH_RECRDRATE, &[8000]) => 0, ok
111247.640 001 dlgc dx_setparm(1, DXCH_RINGCNT, &[1]) => 0, ok
111247.640 001 dlgc dx_setparm(1, DXCH_T_IDD, &[5]) => 0, ok
111247.640 001 dlgc dx_setparm(1, DXCH_TTDATA, &[10]) => 0, ok
111247.640 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
111247.640 xml sCurrConfig_Rule_key=[DialPrefix]
111247.640 rule DialPrefix =
111247.640 001 init config line file load end
111247.640 SetParam ConfigLine_Filename end
111247.671 001 ocxev DoFireDialogic(dwIdx=0, 1, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=0)
111247.671 001 ocxev DoFireDialogic completed
111247.671 001 te LINE_CALLSTATE(1, 0x1, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
111247.671 ocxfn LineOpenDialogic(dxxx=dxxxB1C2, dti=dxxxB1C2, protocol=pdk_na_an_io, opt=, opt=0)
111247.671 init opening straight analog line
111247.671 002 dlgc dx_open(dxxxB1C2) => 2
111247.671 002 DlgcVoice_SetConfig_AwaitCall start
111247.671 002 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C2|dxxxB1C2]
111247.671 002 init config line file not specified. default settings will remain.
111247.671 002 dx_sethook call (LineOpenDialogic)
111247.671 002 dx_sethook 2 DX_ONHOOK ok
111247.671 002 init LineOpenDialogic (analog) ok => [2]
111247.671 002 ocxfn SetParam(2,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
111247.671 SetParam ConfigLine_Filename begin
111247.671 002 tone section start A
111247.671 002 ev TDX_SETHOOK (SetHook Completed)
111247.687 002 dlgc tones_del(2) returned ok
111247.687 002 tone section start B
111247.687 002 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
111247.687 002 init config line file load start (len=11373)
111247.687 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
111247.687 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
111247.687 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
111247.687 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
111247.687 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
111247.687 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
111247.687 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
111247.687 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
111247.687 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
111247.687 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
111247.687 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
111247.687 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
111247.687 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
111247.687 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
111247.687 002 dlgc dx_setparm(2, DXCH_CALLID, &[1]) => 0, ok
111247.687 002 dlgc dx_setparm(2, DXCH_DTMFDEB, &[0]) => 0, ok
111247.687 002 dlgc dx_setparm(2, DXCH_DTMFTLK, &[5]) => 0, ok
111247.687 002 dlgc dx_setparm(2, DXCH_MINRWINK, &[10]) => 0, ok
111247.687 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
111247.703 002 dlgc dx_setparm(2, DXCH_RECRDRATE, &[8000]) => 0, ok
111247.703 002 dlgc dx_setparm(2, DXCH_RINGCNT, &[1]) => 0, ok
111247.703 002 dlgc dx_setparm(2, DXCH_T_IDD, &[5]) => 0, ok
111247.703 002 dlgc dx_setparm(2, DXCH_TTDATA, &[10]) => 0, ok
111247.703 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
111247.703 xml sCurrConfig_Rule_key=[DialPrefix]
111247.703 rule DialPrefix =
111247.703 002 init config line file load end
111247.703 SetParam ConfigLine_Filename end
111247.718 002 ocxev DoFireDialogic(dwIdx=2, 2, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=2)
111247.718 002 ocxev DoFireDialogic completed
111247.718 002 te LINE_CALLSTATE(2, 0x2, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
111247.718 ocxfn LineOpenDialogic(dxxx=dxxxB1C3, dti=dxxxB1C3, protocol=pdk_na_an_io, opt=, opt=0)
111247.718 init opening straight analog line
111247.734 003 dlgc dx_open(dxxxB1C3) => 3
111247.734 003 DlgcVoice_SetConfig_AwaitCall start
111247.734 003 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C3|dxxxB1C3]
111247.734 003 init config line file not specified. default settings will remain.
111247.734 003 dx_sethook call (LineOpenDialogic)
111247.734 003 dx_sethook 3 DX_ONHOOK ok
111247.734 003 init LineOpenDialogic (analog) ok => [3]
111247.734 003 ocxfn SetParam(3,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
111247.734 SetParam ConfigLine_Filename begin
111247.734 003 tone section start A
111247.734 003 ev TDX_SETHOOK (SetHook Completed)
111247.734 003 dlgc tones_del(3) returned ok
111247.734 003 tone section start B
111247.734 003 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
111247.734 003 init config line file load start (len=11373)
111247.734 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
111247.734 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
111247.734 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
111247.734 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
111247.734 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
111247.734 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
111247.734 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
111247.734 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
111247.734 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
111247.734 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
111247.734 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
111247.734 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
111247.734 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
111247.734 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
111247.750 003 dlgc dx_setparm(3, DXCH_CALLID, &[1]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_DTMFDEB, &[0]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_DTMFTLK, &[5]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_MINRWINK, &[10]) => 0, ok
111247.750 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
111247.750 003 dlgc dx_setparm(3, DXCH_RECRDRATE, &[8000]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_RINGCNT, &[1]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_T_IDD, &[5]) => 0, ok
111247.750 003 dlgc dx_setparm(3, DXCH_TTDATA, &[10]) => 0, ok
111247.750 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
111247.750 xml sCurrConfig_Rule_key=[DialPrefix]
111247.750 rule DialPrefix =
111247.750 003 init config line file load end
111247.765 SetParam ConfigLine_Filename end
111247.765 003 ocxev DoFireDialogic(dwIdx=4, 3, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=4)
111247.765 003 ocxev DoFireDialogic completed
111247.765 003 te LINE_CALLSTATE(3, 0x3, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
111247.765 ocxfn LineOpenDialogic(dxxx=dxxxB1C4, dti=dxxxB1C4, protocol=pdk_na_an_io, opt=, opt=0)
111247.765 init opening straight analog line
111247.796 004 dlgc dx_open(dxxxB1C4) => 4
111247.796 004 DlgcVoice_SetConfig_AwaitCall start
111247.796 004 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C4|dxxxB1C4]
111247.796 004 init config line file not specified. default settings will remain.
111247.796 004 dx_sethook call (LineOpenDialogic)
111247.796 004 dx_sethook 4 DX_ONHOOK ok
111247.796 004 init LineOpenDialogic (analog) ok => [4]
111247.796 004 ocxfn SetParam(4,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
111247.796 SetParam ConfigLine_Filename begin
111247.796 004 tone section start A
111247.796 004 ev TDX_SETHOOK (SetHook Completed)
111247.812 004 dlgc tones_del(4) returned ok
111247.812 004 tone section start B
111247.812 004 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
111247.812 004 init config line file load start (len=11373)
111247.812 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
111247.812 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
111247.812 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
111247.812 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
111247.812 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
111247.812 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
111247.812 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
111247.812 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
111247.812 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
111247.812 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
111247.812 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
111247.812 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
111247.812 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
111247.812 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
111247.812 004 dlgc dx_setparm(4, DXCH_CALLID, &[1]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_DTMFDEB, &[0]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_DTMFTLK, &[5]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_MINRWINK, &[10]) => 0, ok
111247.812 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
111247.812 004 dlgc dx_setparm(4, DXCH_RECRDRATE, &[8000]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_RINGCNT, &[1]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_T_IDD, &[5]) => 0, ok
111247.812 004 dlgc dx_setparm(4, DXCH_TTDATA, &[10]) => 0, ok
111247.812 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
111247.812 xml sCurrConfig_Rule_key=[DialPrefix]
111247.812 rule DialPrefix =
111247.828 004 init config line file load end
111247.828 SetParam ConfigLine_Filename end
111247.828 004 ocxev DoFireDialogic(dwIdx=6, 4, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=6)
111247.828 004 ocxev DoFireDialogic completed
111247.828 004 te LINE_CALLSTATE(4, 0x4, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
111247.828 ocxfn LineOpenDialogic(dxxx=, dti=, protocol=, opt=route, opt=0)
111247.828 init attach and config voice resources.
111247.828 001 init route dxxxB1C1 to dxxxB1C1
111247.828 001 init dxxx init type : analog
111247.828 route resources (dxxxB1C1) call
111247.828 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1
111247.828 dlgc this channel does not link to a bus timeslot
111247.843 001 init supplementary config start
111247.843 002 init route dxxxB1C2 to dxxxB1C2
111247.843 002 init dxxx init type : analog
111247.843 route resources (dxxxB1C2) call
111247.843 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C2
111247.843 dlgc this channel does not link to a bus timeslot
111247.843 002 init supplementary config start
111247.859 003 init route dxxxB1C3 to dxxxB1C3
111247.859 003 init dxxx init type : analog
111247.859 route resources (dxxxB1C3) call
111247.859 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C3
111247.859 dlgc this channel does not link to a bus timeslot
111247.859 003 init supplementary config start
111247.859 004 init route dxxxB1C4 to dxxxB1C4
111247.859 004 init dxxx init type : analog
111247.859 route resources (dxxxB1C4) call
111247.859 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C4
111247.859 004 init supplementary config start
111248.812 001 ocxfn RingsBeforeAnswer(lLineId=1, lRings=0, lParam1=0, strParam2=)
111248.812 002 ocxfn RingsBeforeAnswer(lLineId=2, lRings=0, lParam1=0, strParam2=)
111248.812 003 ocxfn RingsBeforeAnswer(lLineId=3, lRings=0, lParam1=0, strParam2=)
111248.921 004 ocxfn RingsBeforeAnswer(lLineId=4, lRings=0, lParam1=0, strParam2=)
111310.859 001 ev TDX_CST (CST Event Received)
111310.859 001 ev TDX_CST DE_RINGS data=0 ringcount=1 (hli=0x1bde70, hli->chdev=1, hli->linedev=1)
111310.875 001 dx_gtextcallid(1,CLIDINFO_CMPLT) error [128]:[Caller ID info/sub-msg not available]
111310.875 001 dx_gtextcallid(1,CLIDINFO_GENERAL) error [128]:[Caller ID info/sub-msg not available]
111310.875 001 dx_gtextcallid(1,CLIDINFO_CALLID) error [128]:[Caller ID info/sub-msg not available]
111310.859 001 ev TDX_CST DE_RINGS data=0 ringcount=1 (hli=0x1bdc40, hli->chdev=1, hli->linedev=1)
111310.890 001 dx_gtextcallid(1,CLIDINFO_FRAMETYPE) error [128]:[Caller ID info/sub-msg not available]
111310.890 001 dlgc caller id frame type: UNKNOWN [0x00]
111310.890 001 pbx display not supported on this card
111310.890 001 info ktTelControl v2.3.7, Apr 6 2006 18:11:26
111310.890 001 te LINE_CALLSTATE(1, 0x1, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING
111310.890 001 te LINE_LINEDEVSTATE(1, 0x1, 0x2, 0x0, 0x1) (dwIdx=20)
111310.890 001 ocxfn LineAnswer(lLineId=1, lParam=0, strParam=)
111310.937 pbx display (1) [1286]:[invalid device]
111310.937 pbx callid (1) [1286]:[invalid device]
111310.937 dx_sethook(1, DX_OFFHOOK, EV_ASYNC) error [9]:[Device busy]
111310.937 001 ocxev DoFireDialogic(dwIdx=21, 1, 134, [TDX_CST], 0, 0, 0, [DE_RINGS], [ET_RON], []) (dwIdx=21)
111310.937 001 ocxev DoFireDialogic completed
111310.875 001 dx_gtextcallid(1,CLIDINFO_FRAMETYPE) error [128]:[Caller ID info/sub-msg not available]
111310.875 001 dlgc caller id frame type: UNKNOWN [0x00]
111310.875 001 pbx display not supported on this card
111310.875 001 info ktTelControl v2.3.7, Apr 6 2006 18:11:26
111310.875 001 te LINE_CALLSTATE(1, 0x1, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING
111310.875 001 te LINE_LINEDEVSTATE(1, 0x1, 0x2, 0x0, 0x1) (dwIdx=9)
111310.875 001 ocxfn LineAnswer(lLineId=1, lParam=0, strParam=)
111310.890 pbx display (1) [1286]:[invalid device]
111310.890 pbx callid (1) [1286]:[invalid device]
111310.890 dx_sethook(1, DX_OFFHOOK, EV_ASYNC) ok
111310.890 001 ocxev DoFireDialogic(dwIdx=10, 1, 134, [TDX_CST], 0, 0, 0, [DE_RINGS], [ET_RON], []) (dwIdx=10)
111310.890 001 ocxev DoFireDialogic completed
111311.437 001 ev TDX_SETHOOK (SetHook Completed)
111311.437 setting call progress tones according to [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
111311.437 001 dlgc dx_deltones(1) returned ok (DelTones_SetTones_InitCallProgress)
111311.437 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[0]
111311.437 tone an id:DISCONNECT_TAPI1 191 f1:620:200, f2:480:200, cad:30:10:20:10, count:3
111311.453 tone description save hli=0x1bde70, iToneUserID[0]=191 sToneUserName[0]=[DISCONNECT_TAPI1]
111311.453 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[1]
111311.453 tone an id:DISCONNECT_TAPI2:192, f1:550:200, cad:30:10:20:10, count:3
111311.453 tone description save hli=0x1bde70, iToneUserID[1]=192 sToneUserName[1]=[DISCONNECT_TAPI2]
111311.453 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[2]
111311.453 tone an id:DISCONNECT_Telstra:193, f1:425:50, cad:37:5:37:5, count:2
111311.468 tone description save hli=0x1bde70, iToneUserID[2]=193 sToneUserName[2]=[DISCONNECT_Telstra]
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[59]
111311.468 tone ch id:TID_DIAL_LCL:250, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[60]
111311.468 tone ch id:TID_DIAL_INTL:251, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[61]
111311.468 tone ch id:TID_DIAL_XTRA:252, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[62]
111311.468 tone ch id:TID_BUSY1:253, f1:500:200, f2:0:0, cad:55:40,55:40, count:4
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[63]
111311.468 tone ch id:TID_RNGBK1:254, f1:438:138, f2:0:0, cad:130:105,400:200, count:1
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[64]
111311.468 tone ch id:TID_BUSY2:255, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[65]
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[66]
111311.468 tone ch id:TID_DISCONNECT:257, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[67]
111311.468 tone ch id:TID_FAX1:258, f1:2150:50, f2:0:0, cad:25:25,0:0, count:1
111311.468 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[68]
111311.468 tone ch id:TID_FAX2:259, f1:1100:50, f2:0:0, cad:25:25,0:0, count:1
111311.484 001 ev TDX_CST (CST Event Received)
111311.484 001 ev TDX_CST DE_LCON data=2387
111311.484 001 ocxev DoFireDialogic(dwIdx=22, 1, 134, [TDX_CST], 2387, 0, 0, [DE_LCON], [], []) (dwIdx=22)
111311.484 001 ocxev DoFireDialogic completed
111311.515 001 cp_init(1) returned ok (DelTones_SetTones_InitCallProgress)
111311.515 001 ev TDX_CST (CST Event Received)
111311.515 001 ev TDX_CST DE_LCON data=2387
111311.515 001 ocxev DoFireDialogic(dwIdx=11, 1, 135, [TDX_SETHOOK], 0, 0, 0, [DX_OFFHOOK], [CALL_INBOUND], []) (dwIdx=11)
111311.515 001 ocxev DoFireDialogic completed
111311.515 001 te LINE_CALLSTATE(1, 0x1, 0x100, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_CONNECTED
111312.531 001 ocxev DoFireDialogic(dwIdx=13, 1, 134, [TDX_CST], 2387, 0, 0, [DE_LCON], [], []) (dwIdx=13)
111312.531 001 ocxev DoFireDialogic completed
111312.562 001 ocxfn ConvertWav2Vox(hLine=1, lTaskID=363109, strWavFilesIn=redirected.wav, strConvertOptions=, lParam1=1, lParam2=0, strParam1=, strParam2=)
111312.609 conv start on idx 1 [redirected.wav]
111312.609 conv start on token 0 [redirected.wav]
111312.609 conv wav[redirected.wav][Fri Mar 17 09:02:24 2006
] same or older then vox[redirected.vox][Tue May 16 08:45:55 2006
] (modified time comparison). not converting wav->vox.
111312.609 conv out [redirected.vox]
111312.609 evt OnFireConvertWavVoxFinished wParam=1 lParam=0
111312.609 ocxev ConvertWavVoxFinished(1, 363109, redirected.vox, 1, 0, , )
111312.609 001 ocxfn PlayStart(hLine=1, strSoundFile=redirected.vox, lPlayId=363156(0x58a94), lParam1=0, lParam2=0, strParam1=, strParam2=, keys[NotUsed])
111312.609 001 ocxfn PlaySetControlKeys(1,0,,,,,,,,,,)
111312.609 001 play start (hli=0x1bde70, strSoundFile=redirected.vox, lPlayId=363156(0x58a94), lParam1=0, lParam2=0, strParam1=, strParam2=)
111312.625 001 play open(strFname[0]=redirected.vox) => 7, read_bytes=11629/11629, buff_addr=0xc4efd10 (file_created_time=Tue May 16 08:45:55 2006
, file_modified_time=Tue May 16 08:45:55 2006
111312.625 001 dlgc dx_setevtmsk(1, [MASK]) => 0
111312.625 001 dlgc dx_setdigtyp(1, DM_DTMF) => 0
111312.640 001 dlgc dx_clrdigbuf(1) => 0
111312.640 001 dlgc dx_clrsvcond(1) => 0
111312.640 001 dlgc play(1, 0xc4eec70, 0x1c10cc, 0x1c134c, EV_ASYNC) call
111312.640 001 dlgc play(1, 0xc4eec70, 0x1c10cc, 0x1c134c) => 0, hli=0x1bde70
111315.609 001 ev TDX_PLAY (Play Completed)
111315.609 001 cleared dwPlayId: hli=0x1bde70, hli->dwPlayId=0(0x0)
111315.609 001 ocxev PlayEnd(dwLineId=1, dwPlayId=363156)
111315.609 001 ocxev DoFireDialogic(dwIdx=14, 1, 129, [TDX_PLAY], 363156, 0, 0, [], [], []) (dwIdx=14)
111315.609 001 ocxev DoFireDialogic completed
111316.031 001 ocxfn Dial(1,0,[!,],,0,0,,)
111316.031 001 zDial_DxCap.ca_intflg=DX_OPTDIS (else case)
111316.031 001 dx_dial(1,[&,],off) as ca_intflg=2
111316.031 001 dx_dial(1,&,) ok
111317.531 001 ev TDX_DIAL (Dial Completed)
111317.531 001 ocxev DoFireDialogic(dwIdx=15, 1, 132, [TDX_DIAL], 0, 0, 0, [], [], []) (dwIdx=15)
111317.531 001 ocxev DoFireDialogic completed
111317.531 001 ocxev PlayEnd(dwLineId=1, dwPlayId=0)
111319.640 001 ocxfn Dial(1,0,[5596],,0,0,,)
111319.640 001 zDial_DxCap.ca_intflg=DX_OPTDIS (else case)
111319.640 001 dx_dial(1,[5596],off) as ca_intflg=2
111319.640 001 dx_dial(1,5596) ok
111320.203 001 ev TDX_DIAL (Dial Completed)
111320.203 001 ocxev DoFireDialogic(dwIdx=16, 1, 132, [TDX_DIAL], 0, 0, 0, [], [], []) (dwIdx=16)
111320.203 001 ocxfn RecStop(hLine=1, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
111320.203 001 dx_stopch call in RecStop
111320.203 001 dx_stopch 1 ok
111320.203 001 ocxfn PlayStop(hLine=1, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
111320.203 001 dx_stopch call in PlayStop
111320.203 001 ocxfn LineDrop(sLineId=1, sOpt=0)
111320.203 001 dx_sethook(1) call
111320.203 001 dx_sethook 1 DX_ONHOOK ok
111320.203 001 ocxev DoFireDialogic completed
111320.203 001 ocxev PlayEnd(dwLineId=1, dwPlayId=0)
111320.250 001 ev TDX_SETHOOK (SetHook Completed)
111320.250 001 ocxev DoFireDialogic(dwIdx=17, 1, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=17)
111320.250 001 ocxev DoFireDialogic completed
111320.250 001 te LINE_CALLSTATE(1, 0x1, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
111320.250 001 ocxfn RecStop(hLine=1, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
111320.250 001 dx_stopch call in RecStop
111320.250 001 dx_stopch 1 ok
111320.250 001 ocxfn PlayStop(hLine=1, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
111320.250 001 dx_stopch call in PlayStop
111321.281 001 ocxfn RingsBeforeAnswer(lLineId=1, lRings=0, lParam1=0, strParam2=)
I have found strange error in one of log files: Could this be the problem?
111233.14 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210
111233.14 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250
111233.16 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250
In previous post I was trying to use blind hookflash transfer. I just called the system, waited a bit, the system transfered me to the number I need and then hang up. I started hear siren.
There is another log file, I have tried to use monitored transfer. I worked in some funny way: I was listening for another number for a while then my script was starting from begining like I have called again to the system. PBX strings are in attachment.
112752.656 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,0,
112752.750 ------------------------------------------------------------------------------
112752.750 ktTelControl OCX v2.3.7, Apr 6 2006 18:11:09 [For Dialogic]
112752.750 Initialise at 0518 112752.750
112752.750 dlgc Dialogic boards present: dti:0, dxxx:1
112752.812 fn AppInit_Dialogic
112752.812 init test NETWORK devices (1st channel on each board)
112752.812 init test VOICE devices (1st device on each voice board)
112752.906 001 dlgc dx_open(dxxxB1) => 1
112752.906 init config board file [C:\Program Files\VoiceGuide\data\Config.xml]
112752.906 001 init config board file load start (len=5342)
112752.906 001 dlgc dx_setparm(1, DXBD_FLASHTM, &[50]) => 0,
112752.906 001 dlgc dx_setparm(1, DXBD_MINLCOFF, &[50]) => 0,
112752.906 001 dlgc dx_setparm(1, DXBD_MINOFFHKTM, &[250]) => 0,
112752.906 001 dlgc dx_setparm(1, DXBD_MINSLOFF, &[2]) => 0,
112752.906 001 dlgc dx_setparm(1, DXBD_MINSLON, &[1]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_MINTIOFF, &[5]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_MINTION, &[5]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_OFFHDLY, &[50]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_PAUSETM, &[100]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_S_BNC, &[4]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_T_IDD, &[15]) => 0,
112752.921 001 dlgc dx_setparm(1, DXBD_TTDATA, &[10]) => 0,
112752.921 001 init config board file load end
112752.953 002 dlgc dx_open(dxxxB1C1) => 2
112752.953 dlgc dxxxB1C1 id=0x6021, family=2, devmode=0, network=3(Analog), bus=0, encode=1
112752.953 ft_play=0x57ff, ft_record=0x5fff, ft_tone=0x7, ft_e2p_brd_cfg=0x6, ft_fax=0x30
112752.953 002 dlgc dx_close(2) ok (channel dxxxB1C1)
112752.953 001 dlgc dx_close(1) ok (board dxxxB1)
112752.953 init enable event processing
112752.953 gc gc_start call
112752.953 eng CtEventPolling thread start
112754.187 000 ocxfn SetParam(0,VgIniFilename,c:\program files\voiceguide\VG.INI,0)
112754.187 SetParam VgIniFilename
112754.203 ocxfn GetLineCount() => 0
112754.359 ocxfn LineOpenDialogic(dxxx=dxxxB1C1, dti=dxxxB1C1, protocol=pdk_na_an_io, opt=, opt=0)
112754.359 init opening straight analog line
112754.359 001 dlgc dx_open(dxxxB1C1) => 1
112754.359 001 DlgcVoice_SetConfig_AwaitCall start
112754.359 001 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C1|dxxxB1C1]
112754.359 001 init config line file not specified. default settings will remain.
112754.359 001 dx_sethook call (LineOpenDialogic)
112754.359 001 dx_sethook 1 DX_ONHOOK ok
112754.359 001 init LineOpenDialogic (analog) ok => [1]
112754.359 001 ocxfn SetParam(1,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
112754.359 SetParam ConfigLine_Filename begin
112754.359 001 tone section start A
112754.359 001 ev TDX_SETHOOK (SetHook Completed)
112754.359 001 dlgc tones_del(1) returned ok
112754.359 001 tone section start B
112754.359 001 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
112754.359 001 init config line file load start (len=11373)
112754.359 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
112754.359 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
112754.359 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
112754.359 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
112754.359 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
112754.359 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
112754.359 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
112754.359 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
112754.359 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
112754.359 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
112754.359 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
112754.359 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
112754.359 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
112754.359 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
112754.375 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
112754.375 001 dlgc dx_setparm(1, DXCH_CALLID, &[1]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_DTMFDEB, &[0]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_DTMFTLK, &[5]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_MINRWINK, &[10]) => 0, ok
112754.375 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
112754.375 001 dlgc dx_setparm(1, DXCH_RECRDRATE, &[8000]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_RINGCNT, &[1]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_T_IDD, &[5]) => 0, ok
112754.375 001 dlgc dx_setparm(1, DXCH_TTDATA, &[10]) => 0, ok
112754.375 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
112754.375 xml sCurrConfig_Rule_key=[DialPrefix]
112754.375 rule DialPrefix =
112754.375 001 init config line file load end
112754.390 SetParam ConfigLine_Filename end
112754.406 001 ocxev DoFireDialogic(dwIdx=0, 1, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=0)
112754.406 001 ocxev DoFireDialogic completed
112754.406 001 te LINE_CALLSTATE(1, 0x1, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
112754.406 ocxfn LineOpenDialogic(dxxx=dxxxB1C2, dti=dxxxB1C2, protocol=pdk_na_an_io, opt=, opt=0)
112754.406 init opening straight analog line
112754.406 002 dlgc dx_open(dxxxB1C2) => 2
112754.406 002 DlgcVoice_SetConfig_AwaitCall start
112754.406 002 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C2|dxxxB1C2]
112754.406 002 init config line file not specified. default settings will remain.
112754.406 002 dx_sethook call (LineOpenDialogic)
112754.406 002 dx_sethook 2 DX_ONHOOK ok
112754.406 002 init LineOpenDialogic (analog) ok => [2]
112754.406 002 ocxfn SetParam(2,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
112754.406 SetParam ConfigLine_Filename begin
112754.406 002 tone section start A
112754.406 002 ev TDX_SETHOOK (SetHook Completed)
112754.406 002 dlgc tones_del(2) returned ok
112754.406 002 tone section start B
112754.406 002 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
112754.406 002 init config line file load start (len=11373)
112754.406 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
112754.406 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
112754.406 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
112754.406 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
112754.406 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
112754.421 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
112754.421 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
112754.421 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
112754.421 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
112754.421 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
112754.421 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
112754.421 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
112754.421 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
112754.421 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
112754.421 002 dlgc dx_setparm(2, DXCH_CALLID, &[1]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_DTMFDEB, &[0]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_DTMFTLK, &[5]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_MINRWINK, &[10]) => 0, ok
112754.421 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
112754.421 002 dlgc dx_setparm(2, DXCH_RECRDRATE, &[8000]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_RINGCNT, &[1]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_T_IDD, &[5]) => 0, ok
112754.421 002 dlgc dx_setparm(2, DXCH_TTDATA, &[10]) => 0, ok
112754.421 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
112754.421 xml sCurrConfig_Rule_key=[DialPrefix]
112754.421 rule DialPrefix =
112754.421 002 init config line file load end
112754.437 SetParam ConfigLine_Filename end
112754.453 002 ocxev DoFireDialogic(dwIdx=2, 2, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=2)
112754.453 002 ocxev DoFireDialogic completed
112754.453 002 te LINE_CALLSTATE(2, 0x2, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
112754.453 ocxfn LineOpenDialogic(dxxx=dxxxB1C3, dti=dxxxB1C3, protocol=pdk_na_an_io, opt=, opt=0)
112754.453 init opening straight analog line
112754.453 003 dlgc dx_open(dxxxB1C3) => 3
112754.453 003 DlgcVoice_SetConfig_AwaitCall start
112754.453 003 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C3|dxxxB1C3]
112754.453 003 init config line file not specified. default settings will remain.
112754.453 003 dx_sethook call (LineOpenDialogic)
112754.453 003 dx_sethook 3 DX_ONHOOK ok
112754.453 003 init LineOpenDialogic (analog) ok => [3]
112754.453 003 ocxfn SetParam(3,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
112754.453 SetParam ConfigLine_Filename begin
112754.453 003 tone section start A
112754.453 003 ev TDX_SETHOOK (SetHook Completed)
112754.468 003 dlgc tones_del(3) returned ok
112754.468 003 tone section start B
112754.468 003 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
112754.468 003 init config line file load start (len=11373)
112754.468 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
112754.468 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
112754.468 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
112754.468 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
112754.468 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
112754.468 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
112754.468 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
112754.468 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
112754.468 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
112754.468 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
112754.468 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
112754.468 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
112754.468 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
112754.468 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
112754.468 003 dlgc dx_setparm(3, DXCH_CALLID, &[1]) => 0, ok
112754.468 003 dlgc dx_setparm(3, DXCH_DTMFDEB, &[0]) => 0, ok
112754.468 003 dlgc dx_setparm(3, DXCH_DTMFTLK, &[5]) => 0, ok
112754.468 003 dlgc dx_setparm(3, DXCH_MINRWINK, &[10]) => 0, ok
112754.468 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
112754.468 003 dlgc dx_setparm(3, DXCH_RECRDRATE, &[8000]) => 0, ok
112754.468 003 dlgc dx_setparm(3, DXCH_RINGCNT, &[1]) => 0, ok
112754.484 003 dlgc dx_setparm(3, DXCH_T_IDD, &[5]) => 0, ok
112754.484 003 dlgc dx_setparm(3, DXCH_TTDATA, &[10]) => 0, ok
112754.484 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
112754.484 xml sCurrConfig_Rule_key=[DialPrefix]
112754.484 rule DialPrefix =
112754.484 003 init config line file load end
112754.484 SetParam ConfigLine_Filename end
112754.484 003 ocxev DoFireDialogic(dwIdx=4, 3, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=4)
112754.484 003 ocxev DoFireDialogic completed
112754.484 003 te LINE_CALLSTATE(3, 0x3, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
112754.484 ocxfn LineOpenDialogic(dxxx=dxxxB1C4, dti=dxxxB1C4, protocol=pdk_na_an_io, opt=, opt=0)
112754.484 init opening straight analog line
112754.500 004 dlgc dx_open(dxxxB1C4) => 4
112754.500 004 DlgcVoice_SetConfig_AwaitCall start
112754.500 004 init tones not set by TSF File as EDX_FEATUREDISABLED (TSF feature is disabled in Configuration Manager Advanced Options) [dxxxB1C4|dxxxB1C4]
112754.500 004 init config line file not specified. default settings will remain.
112754.500 004 dx_sethook call (LineOpenDialogic)
112754.500 004 dx_sethook 4 DX_ONHOOK ok
112754.500 004 init LineOpenDialogic (analog) ok => [4]
112754.500 004 ocxfn SetParam(4,ConfigLine_Filename,C:\Program Files\VoiceGuide\data\ConfigLine.xml,0)
112754.500 SetParam ConfigLine_Filename begin
112754.500 004 tone section start A
112754.500 004 ev TDX_SETHOOK (SetHook Completed)
112754.500 004 dlgc tones_del(4) returned ok
112754.500 004 tone section start B
112754.500 004 init config line as per [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
112754.500 004 init config line file load start (len=11373)
112754.500 tone TID_BUSY1:253 500:200 0:0 55:40 55:40 4
112754.500 tone TID_BUSY2:255 500:200 525:175 55:40 55:40 4
112754.500 tone TID_DIAL_LCL:250 340:40 440:40 100:0 0:0 1
112754.500 tone TID_DIAL_INTL:251 340:40 440:40 100:0 0:0 1
112754.500 tone TID_DIAL_XTRA:252 340:40 440:40 100:0 0:0 1
112754.500 tone TID_DISCONNECT:257 500:200 525:175 55:40 55:40 4
112754.500 tone TID_FAX1:258 2150:50 0:0 25:25 0:0 1
112754.500 tone TID_FAX2:259 1100:50 0:0 25:25 0:0 1
112754.500 tone TID_RNGBK1:254 438:138 0:0 130:105 400:200 1
112754.500 tone TID_RNGBK2:256 438:138 438:138 130:105 400:200 1
112754.500 tone DISCONNECT_TAPI1:191 620:200 480:200 30:10 20:10 3
112754.500 tone DISCONNECT_TAPI2:192 550:200 0:0 30:10 20:10 3
112754.500 tone DISCONNECT_Telstra:193 425:50 0:0 37:5 37:5 2
112754.500 commented out tone defintion encountered (path=[<Samples><Tone>]!=[<Tones><Tone>])
112754.515 004 dlgc dx_setparm(4, DXCH_CALLID, &[1]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_DTMFDEB, &[0]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_DTMFTLK, &[5]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_MINRWINK, &[10]) => 0, ok
112754.515 dlgc parm [DXCH_PLAYRDRATE] not recognized. (XmlHandler_ConfigLine_endElement)
112754.515 004 dlgc dx_setparm(4, DXCH_RECRDRATE, &[8000]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_RINGCNT, &[1]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_T_IDD, &[5]) => 0, ok
112754.515 004 dlgc dx_setparm(4, DXCH_TTDATA, &[10]) => 0, ok
112754.515 xml sCurrConfig_Rule_key=[sendDisconnectOnLoopCurrentDrop]
112754.515 xml sCurrConfig_Rule_key=[DialPrefix]
112754.515 rule DialPrefix =
112754.515 004 init config line file load end
112754.531 SetParam ConfigLine_Filename end
112754.531 004 ocxev DoFireDialogic(dwIdx=6, 4, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=6)
112754.531 004 ocxev DoFireDialogic completed
112754.531 004 te LINE_CALLSTATE(4, 0x4, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
112754.531 ocxfn LineOpenDialogic(dxxx=, dti=, protocol=, opt=route, opt=0)
112754.531 init attach and config voice resources.
112754.531 001 init route dxxxB1C1 to dxxxB1C1
112754.531 001 init dxxx init type : analog
112754.531 route resources (dxxxB1C1) call
112754.531 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1
112754.531 dlgc this channel does not link to a bus timeslot
112754.531 001 init supplementary config start
112754.546 002 init route dxxxB1C2 to dxxxB1C2
112754.546 002 init dxxx init type : analog
112754.546 route resources (dxxxB1C2) call
112754.546 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C2
112754.546 dlgc this channel does not link to a bus timeslot
112754.546 002 init supplementary config start
112754.546 003 init route dxxxB1C3 to dxxxB1C3
112754.546 003 init dxxx init type : analog
112754.546 route resources (dxxxB1C3) call
112754.546 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C3
112754.546 003 init supplementary config start
112754.562 004 init route dxxxB1C4 to dxxxB1C4
112754.562 004 init dxxx init type : analog
112754.562 route resources (dxxxB1C4) call
112754.562 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C4
112754.562 dlgc this channel does not link to a bus timeslot
112754.562 004 init supplementary config start
112755.453 001 ocxfn RingsBeforeAnswer(lLineId=1, lRings=0, lParam1=0, strParam2=)
112755.562 002 ocxfn RingsBeforeAnswer(lLineId=2, lRings=0, lParam1=0, strParam2=)
112755.562 003 ocxfn RingsBeforeAnswer(lLineId=3, lRings=0, lParam1=0, strParam2=)
112755.562 004 ocxfn RingsBeforeAnswer(lLineId=4, lRings=0, lParam1=0, strParam2=)
112833.109 001 ev TDX_CST (CST Event Received)
112833.109 001 ev TDX_CST DE_RINGS data=0 ringcount=1 (hli=0x1bd9f8, hli->chdev=1, hli->linedev=1)
112833.109 001 dx_gtextcallid(1,CLIDINFO_CMPLT) error [128]:[Caller ID info/sub-msg not available]
112833.109 001 dx_gtextcallid(1,CLIDINFO_GENERAL) error [128]:[Caller ID info/sub-msg not available]
112833.109 001 dx_gtextcallid(1,CLIDINFO_CALLID) error [128]:[Caller ID info/sub-msg not available]
112833.109 001 ev TDX_CST DE_RINGS data=0 ringcount=2 (hli=0x1bdc40, hli->chdev=1, hli->linedev=1)
112833.125 001 dx_gtextcallid(1,CLIDINFO_CALLID) error [128]:[Caller ID info/sub-msg not available]
112833.125 001 dx_gtextcallid(1,CLIDINFO_FRAMETYPE) error [128]:[Caller ID info/sub-msg not available]
112833.125 001 dlgc caller id frame type: UNKNOWN [0x00]
112833.125 001 pbx display not supported on this card
112833.125 001 te LINE_LINEDEVSTATE(1, 0x1, 0x2, 0x0, 0x2) (dwIdx=43)
112833.125 001 ocxev DoFireDialogic(dwIdx=44, 1, 134, [TDX_CST], 0, 0, 0, [DE_RINGS], [ET_RON], []) (dwIdx=44)
112833.125 001 ocxev DoFireDialogic completed
112833.125 001 info ktTelControl v2.3.7, Apr 6 2006 18:11:26
112833.125 001 te LINE_CALLSTATE(1, 0x1, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING
112833.125 001 te LINE_LINEDEVSTATE(1, 0x1, 0x2, 0x0, 0x1) (dwIdx=9)
112833.125 001 ocxfn LineAnswer(lLineId=1, lParam=0, strParam=)
112833.125 pbx display (1) [1286]:[invalid device]
112833.125 pbx callid (1) [1286]:[invalid device]
112833.125 dx_sethook(1, DX_OFFHOOK, EV_ASYNC) ok
112833.125 001 ocxev DoFireDialogic(dwIdx=10, 1, 134, [TDX_CST], 0, 0, 0, [DE_RINGS], [ET_RON], []) (dwIdx=10)
112833.671 001 ev TDX_SETHOOK (SetHook Completed)
112833.671 setting call progress tones according to [C:\Program Files\VoiceGuide\data\ConfigLine.xml]
112833.671 001 dlgc dx_deltones(1) returned ok (DelTones_SetTones_InitCallProgress)
112833.671 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[0]
112833.671 tone an id:DISCONNECT_TAPI1 191 f1:620:200, f2:480:200, cad:30:10:20:10, count:3
112833.687 tone description save hli=0x1bd9f8, iToneUserID[0]=191 sToneUserName[0]=[DISCONNECT_TAPI1]
112833.687 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[1]
112833.687 tone an id:DISCONNECT_TAPI2:192, f1:550:200, cad:30:10:20:10, count:3
112833.687 tone description save hli=0x1bd9f8, iToneUserID[1]=192 sToneUserName[1]=[DISCONNECT_TAPI2]
112833.687 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[2]
112833.687 tone an id:DISCONNECT_Telstra:193, f1:425:50, cad:37:5:37:5, count:2
112833.703 tone description save hli=0x1bd9f8, iToneUserID[2]=193 sToneUserName[2]=[DISCONNECT_Telstra]
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[59]
112833.703 tone ch id:TID_DIAL_LCL:250, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[60]
112833.703 tone ch id:TID_DIAL_INTL:251, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[61]
112833.703 tone ch id:TID_DIAL_XTRA:252, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[62]
112833.703 tone ch id:TID_BUSY1:253, f1:500:200, f2:0:0, cad:55:40,55:40, count:4
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[63]
112833.703 tone ch id:TID_RNGBK1:254, f1:438:138, f2:0:0, cad:130:105,400:200, count:1
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[64]
112833.703 tone ch id:TID_BUSY2:255, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[65]
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[66]
112833.703 tone ch id:TID_DISCONNECT:257, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
112833.703 001 zTonesFromConfigLine tone entry found iTonesFromConfigLine_ArrIdx=[67]
112833.703 tone ch id:TID_FAX1:
Trace shows that VG issued a hookflash, then dialeed the number and then hung up.
Is that the way that transfers are usually performed on this PBX?
How do you do manual trasnfers usually?
