fluffybunny Report post Posted 05/17/2006 02:58 PM I have a date in a database which is in the format DD/MM/YY HH:NN:SS I want to see if this date is more than 'x' days ago, where x is another field in the database i.e. DTRecord = 23/4/06 13:06:00 AgeRecord=15 I am guessing I do d DBLookup for the two fields, and then use an evaluate expression and I evaluate this : #$RV_DD/$RV_MM/$RV_YY $RV_HH:$RV_NN:$RV_SS# - #$RV[DBLookup_1_1]# > $RV[ DBLookup_2_1] and this should return true if it is more than 15 days ago, otherwise it will return false. Is this correct? Cheers Simon Share this post Link to post
Guest fmonroy Report post Posted 05/18/2006 03:37 AM what kind of database are you using? in most databases you can do something like: select TODAY - DATE_COLUMN from YOUR_TABLE and the result is in days, so you only need to compare with AgeRecord I hope it helps. I have a date in a database which is in the format DD/MM/YY HH:NN:SS I want to see if this date is more than 'x' days ago, where x is another field in the database i.e. DTRecord = 23/4/06 13:06:00 AgeRecord=15 I am guessing I do d DBLookup for the two fields, and then use an evaluate expression and I evaluate this : #$RV_DD/$RV_MM/$RV_YY $RV_HH:$RV_NN:$RV_SS# - #$RV[DBLookup_1_1]# > $RV[ DBLookup_2_1] and this should return true if it is more than 15 days ago, otherwise it will return false. Is this correct? Cheers Simon Share this post Link to post
fluffybunny Report post Posted 05/18/2006 09:14 AM That sounds interesting. I'm using an Access databse and what I want to acheive is the deletion of any records over 15 days old. Each record has a date/time field which has the date/time the record is created. The age of the fields to be deleted (i.e. 15 days) is held in a field in another table. Can I do this all in one fell swoop with a DBlookup module in VG? Share this post Link to post
SupportTeam Report post Posted 05/18/2006 09:18 AM Can I do this all in one fell swoop with a DBlookup module in VG? Should be OK, just setup your SQL statement to correctly do date comparison/selection. Share this post Link to post
fluffybunny Report post Posted 05/18/2006 10:59 AM Struggling a bit here...... My DB lookup is doing : SELECT RefNumber,Filename,DTRecorded,Status FROM Intray WHERE Status='Read' AND DTRecorded < #$RV_DD/$RV_MM/$RV_YY#-15 ..but this is selecting all records with Status='Read' I was hoping the -15 at the end would filter out only those from 15 days ago. I attach the trace to show whats occurring. log.zip Share this post Link to post
fluffybunny Report post Posted 05/18/2006 01:07 PM This is doing my head in now...... I'm trying it a different way now. As I just want to delete some old records over 5 days old I'm trying this: UPDATE Intray SET Status='Deleted' WHERE DTRead< Now() AND DTRecorded < Now()-5 The trace says the update worked ok, but there are records in my database over 5 days old (i.e. DTRecorded is , say, 5/05/2006 16:43:22, DTRead is , say, 10/05/2006 10:00:00, but whose Status is not being changed to Deleted. I simply cant see why this wont work. Is it something to do with using the "<" operator? Trace included, as always. 0518vgm.zip Share this post Link to post
fluffybunny Report post Posted 05/18/2006 02:25 PM Oh what a pillock. If I had looked closer I would have seen that my column in Access was just a tiny bit too small and when I thought DTRecorded was 5/05/2006 it was in fact 15/05/2006 because the leading '1' wasnt being displayed! So, it was working after all. Sorry for wasting everyones time. However....(!!!!) I now cant seem to do a simple thing like delete a file using the RUN module... I am trying to do this : command.com /c del c:\freshdirect\messages\$RV[selectAgedMessage_2_1].wav in my RUN module. $RV[selectedAgedMessage_2_1].wav is a real message, but it doesent want to delete it from c:\freshdirect\messages Probably something simple, but my brain is frazzled now. Share this post Link to post
SupportTeam Report post Posted 05/21/2006 07:57 PM try redirecting the output of the DOS command to a file, theat should inform you why the file was not deleted. Share this post Link to post
Guest fmonroy Report post Posted 05/22/2006 08:22 PM but it doesent want to delete it from c:\freshdirect\messageswhat? Share this post Link to post
