ktruk Report post Posted 05/19/2006 10:52 AM I would like to specify a timeout path of say 0.5 second... eg: on {timeout 0.5} goto [ModuleX] I can't seem to tell from the debug logs if this actually works. Can you confirm if this is supported or not? Or is it only integer values. I know I can play a short silence to create a similar pause, but this is too much effort. Ideally, I just want to introduce a slight pause between prompts, but not a full second. Thanks. Share this post Link to post
SupportTeam Report post Posted 05/21/2006 08:07 PM At this stage officially only integer values are supported, but decimal values may work depending on version used... have you tried it? Share this post Link to post
