Dialogic Vs Non-dialogic Outdialqueadd
I'm using NON-Dialogic VG on my Laptop and Dialogic VG on my client's Desktop. Both running XP Pro. My OutDialQueAdd works fine on the laptop, but fails with "Incorrect # of parameters" on the Dialogic version.
I have Microsoft Access installed on the Laptop, but NOT on the Desktop running Dialogic VG...is that a problem? Even so, if I go into the ODBC Datasource Manager, I CAN define a MS Access Datasource.
Any suggestions would be appreciated.
This is the call that works with the Non-Dialogic Version but NOT with the Dialogic Version.
VG.Dialer_OutQueAdd(dial_prefix + current_phone,0,0,0,"","",1,"","","","",0,2,5,"")
Dev Environment is Sybase PowerBuilder 8.0.
There is an extra string parameter in the Dialogic version, adding an extra "" to the end of Dialer_OutQueAdd parameters should make it work
